Electrolytic capacitor identification
David Rickman
Feb 16, 2018
6
This capacitor in my Garmin 551dv fishfinder blew and I need help identifying it and possibly where to get a new one.
Robert_fay
Jun 15, 2017
124
While I have not identified the exact cap from my previous searches I agree with @hevans1944
405 is likely a dat code 05 month of 2004
220 is likely 220uF
50Z is going to be 50volts and then Z will either be a tolerance or series indicator
David Rickman
Feb 16, 2018
6
While I dont disagree with you, i have no way of finding that out. I want to believe it could have happened due excessive heat, ut is in a black case in direct sunlight or it could jave happened when i had to jumpstart my boat. But for the 88 cents plus shipping i will gladly replace it and see.
David Rickman
Feb 16, 2018
6
Yes, it goes right near where the power cable connects, right where im pointing with the screwdriver, you can see the burn mark on the casing too.
David Rickman
Feb 16, 2018
6
Is the pic uploading?
kellys_eye
Jun 25, 2010
6,512
The adjacent inductor points to an SMPS-derived supply onboard - quite common - and blown capacitors are a definite problem in some designs so your fault could just be pertinent to the design but the severity of the failure is quite surprising.
If/when you change it I'd recommend powering up with the lid off and letting it run for a good few hours to make sure there isn't something else amiss.
