Electrolytic Capacitor Substitution Question
N
nucleus
trying to repair RCA VR688HF VCR (because stand-alone VCRs
apparently are not manufactured/sold anymore), have reviewed
most of VCR repair FAQs, done most of things suggested there
except replace components in power supply, VCR still has
symptom of erratic behavior.
found 5 caps questionable in PS with power on, scrounged
duplicates for 4, have not found a cap substitution FAQ. the
5th cap is 100mf/200v.
question: if i substitute a 560mf/200v for the questionable
100mf/200v, would this cause damage or just better filtering?
Jerry G.
If this is a main filter capacitor, it will demand a much greater inrush
current when the supply starts up. I would order the correct value. You
could probably get away with a 150 to 220 mF cap.
With simple filtering circuits, in theory, the greater the cap value the
better the filtering. Just remember that when the power supply starts
up it has to bring the cap up to charge. A greater size cap will take
greater current during the charge time.
Jerry G.
Eeyore
It sounds like the bulk reservoir car. Using a cap nearly 6 times the original
value could very likely blow fuses at turn-on for example.
You can't be trying very hard if you can't find a 100uF/200V btw. Maybe look for
a 250V rating ?
Graham
p.s. please don't write mF btw - that means milli-farads.
Paige D'Winter
Google is your friend dumbass.
K
Krusty
On Tue, 23 Oct 2007 06:30:28 -0700 "Paige D'Winter"
And no one is yours, dickcheese. How sad is that?
