Adam Funk
- Jan 1, 1970
- 0
I wired up a 556 (two 555 timers on one chip) as follows:
Timer A:
astable circuit with equal mark & space width,
R = 267 Ω, C = 1000 µF (electrolytic with 25 V rating),
output: 320 Ω in series with an LED,
also tied to the reset pin on Timer B
Timer B:
same astable timing arrangement,
R = 100 k Ω, C = 10 nF (non-electrolytic),
output: piezo speaker in series with a resistor
I powered this concoction with a 9 V battery, and got more or less the
expected result: the speaker alternates between silence & a
high-pitched noise, and the LED lights up when the speaker is on. The
first few cycles of timer A are a bit irregular (it stays on for a few
seconds before first switching off), but then it evens out.
When I supply the whole circuit with 3 V (two AAAs) instead, however,
(and reduce the resistance in series with the LED accordingly), the
LED stays on all & the speaker whistles all the time.
My questions:
Is tying the output of timer A to the reset pin of timer B the most
correct way to switch B on and off with A?
One of the books of 555 circuits says that electrolytic capacitors
only work properly as capacitors above 10% of their rated voltage. Is
this why timer A doesn't work on a 3 V supply?
Even with the 9 V supply, the LED doesn't go completely off when the
speaker does --- it's just noticeably dimmer than when the speaker is
on. Why?
Timer A:
Timer B:
My questions:
on. Why?
