Electronic Compass
Guest
How can i make an electronics compass?
It can consist of a circle of LEDs and the LED facing north will light up.
OR:-
A single LED and moment the device faces north the LED lights up.
mixos1
Administrator
Jul 13, 2003
581
You must start by identifing the magnetic compass sensor you will use. Some common sensors are:
KMZ52 from Philips
HM55B from Hitachi
1490 Compass Sensor
Then you can take a look to some schematics/application notes to see how this can be intergrated to your system:
1490 Digital Compass
http://www.imagesco.com/articles/1490/01.html
Electronic Compass Design using KMZ51 and KMZ52
http://www.web-ee.com/primers/files/AN00022_COMPASS.pdf
Y
Yevgenip
You are not the first in this forum who wants to make a compass. I suggest using a regular mechanic compass - much easier if you only want to look at it.
Dazza
Jun 21, 2004
591
Hi Siddharth,
I think that would be a very interesting project to take on :D, although I think it would be difficult to make an electronic compass, that could improve on the simplicity and reliability of a mechanical compass.
I know which one I would choose, if I was heading into the outback ;).
Good luck, I hope you are planning on posting your progress here 8).
Guest
It is just my curiosity.
I just would like to find ideas to make one; how to approach it.
If a particular method is simple cheap then i'll make one
1490 looks good.
hotwaterwizard2
Jan 8, 2004
2,022
Try These Links!
Electronic Compass
http://users.frii.com/dlc/robotics/projects/botproj.htm
http://www-2.cs.cmu.edu/~danieln/digital_compass.htm
