Electronic Component: CL220 Regulator
KAKU1
Sep 6, 2021
CL220 is a high voltage, temperature-compensated, 20mA constant current regulator. The device operates at up to 220V, and is accurate to ±10% over a 5 - 160V range. The device can be used as a two-terminal, constant-current source or a constant-current sink.
CL220 Features
• 5.0 to 220V operating range (VA-B)
• 20mA ±10% at 5.0 - 160V
• 0.01% / °C typical temperature coefficient
• Packages Types:
- TO-252 (D-PAK)
[SIZE=10.5pt]•[/SIZE][SIZE=10.5pt] Can be paralleled for higher current[/SIZE]
pychne88u
Sep 30, 2021
 hi your topic is CL220 Regulator A typical application for the CL220 is to drive LEDs with a constant current of 20mA.
Poetry for Instagram
Bobfadi1
Aug 23, 2022
The CL220 is a temperature compensated, high-voltage constant-current regulator that operates over a wide range of voltages up to 220V. This device operates as a two-terminal constant-current source or sink and is commonly used to drive LEDs with a constant current of 20mA. Multiple CL220s can be used in parallel to increase current capacity. The CL220 comes in a TO-220 package for easy installation and is available in several configurations.
