Help Identifying this electronic component ?
MikeyTX
Feb 2, 2023
4
Can some one Please help me identify this item I think its a diode but i need to replace one and cant find one with this same makings on it, does anyone know what it is????"? it has 10 201 on the component. Thank You Mike
kellys_eye
Jun 25, 2010
6,512
What is the component designation (printed on the PCB but hidden by your blue circle line...)
kellys_eye
Jun 25, 2010
6,512
If it is C31 then the part is likely to be a 200uF capacitor rated at 10V - still difficult to tell if the designation relates to that part - need a wider shot of that area of board.
As noted, more likely to be in the wider shot.
I'd tend to go for the marking just to the right side of your photo.
14,487
it's the wrong marking for 200uF
the rule ( sometimes broken) for surface mount electro/tant's is ......
105 = 1uF
106 = 10uF
107 = 100uF
etc
227 = 220uF
Martaine2005
May 12, 2015
5,318
What’s above C64, C27 and then something 2. That should be that components refdes.
It won’t be long before all components look the same!.
Martin
kellys_eye
Jun 25, 2010
6,512
Well, we know it's polarised so it's either a capacitor or a diode. It's designation seems to be C31 (needs clarification) but a quick meter test will reveal if it's a diode and may even show enough to prove it as a capacitor. It certainly doesn't look faulty but looks can be deceiving.
Have you done a meter check on it?
MikeyTX
Feb 2, 2023
4
Ha, Ha, Ha, your so funny Martaine2005, anyways i'm sorry you all, i was out of town when that joke came across. ok here is a new revised picture of the problem, its not my board but belongs to a good friend of mine, this is the correct picture with the problem, the other pictures were taken on the wrong part of the board. Please help me identify this burn out item. thanks mike.
kellys_eye
Jun 25, 2010
6,512
Looks like you started another thread on this but the answer remains the same - capacitor, 200uF 10V. Blown due to reverse power application, more faults likely all over the board. Not fixable.
wrinke
Feb 25, 2023
16
I was jumping between threads and I notice this. Can I ask you from what do you identify this item? Just for didattic purpose
Martaine2005
May 12, 2015
5,318
The code on the SMD product or the PCB reference. Is my take on it.
Martin
