Electronic door lock is safe?
JoneQ
Dec 26, 2019
4
If fire breaks out, the electronic door lock will be melted? If happen, it will be dangerous. People in the house will be trapped.
My neighbor installed an electronic door lock. My wife wants to replace our old door lock.
But I am very worried!! Electronic door lock is safe? Is it worth buying?
Nanren888
Nov 8, 2015
622
Generally electrical doors are done not with an electronic lock, but with an electric strike, the side that is in the wall.
As with all things, there are two types. Some fail/power off open and some default to locked.
Martaine2005
May 12, 2015
5,315
I doubt it would cause a trapped scenario. Plastic melting point is 200-300 degrees C. Wood burning point is apprx 300 degrees C. Aluminium is about 650-700 degrees C. Steel is 1300-1600 etc.
One would hope the occupants were out long before these temperatures.
Martin
ChosunOne
Jun 20, 2010
491
If a fire melts a door lock, then the fire at that door is pretty intense, so that door is not a way out anyway---because it's already vigorously ablaze, and it doesn't matter if it melted an electronic lock or a mechanical lock (which is just as susceptible to melting).
As Nanren said, electronic door strikes come in two flavors: "Fail-safe" (unlocks when power fails) and "Fail-secure" (locks when power fails). In homes, Fail-safe is almost always used, and you need a battery backup in case of power outage, so it doesn't leave your home unsecure.
Tha fios agaibh
Aug 11, 2014
2,253
I've got electronic locks which have the electronics on the outside and locking mechanism which opens mechanically from the inside. Kind of like how you can open your car door from the inside with a dead battery.
If it's an electrical striker it should default open on power loss according to fire code.
mrgrtt123
Jan 6, 2020
11
I am not that sure since there will always be a pro and con on everything.
Electronic door locks rely heavily on technology, and technology doesn't always work according to plan, there is a possibility that the lock will encounter an error and not respond to your phone or remote.
Most electronic door locks come with a manual lock that you can open using a key, providing you with an alternative way to get in should the software encounter issues.
Nanren888
Nov 8, 2015
622
I suspect that's the driver for electric strikes.In the simple case, you have a standard lock with the ability to operate without power. The strike simply allows it to open without the manual lock opening.
A little different if you want deadbolts.
HellasTechn
Apr 14, 2013
1,579
It is always a good idea to be able to operate things manually. Can you figure out a way to manually bypass the electronic lock from inside? For example to attatch some small mechanism that will allow you to pull open the doors latch in case of emergency or failure while use the electronic lock under normal circumstances?
There you go, like this :
Electronic locks are largely for use in things like hospitals and government offices etc. to keep the public from certain areas with access via rfid tags for ease of employee entry.
In these, the doors open automatically by power down during any fire alarm situation.
I can't think of any need for one in a domestic situation.
All sound like a "keeping up with the Jones's" situation.
If the lock is worth it's salt, it should be fail safe......... i.e. release the door lock mechanism when a fire/smoke is detected.
Look at how fire doors in hospitals etc. release automatically without power and close.(fail safe)
bidrohini
Feb 1, 2023
219
Electronic door locks are typically designed to withstand high temperatures and are made of materials that are resistant to heat and flames. That being said, it's always a good idea to have a backup plan in case of a fire, such as a secondary exit or a manual override for the door lock.
Additionally, electronic door locks may have other security risks, such as vulnerabilities to hacking or power outages. It's important to choose a reputable brand and model, and to make sure that the lock is properly installed and configured.
