Electronic Inks!
cjdelphi
Oct 26, 2011
1,166
Website sells these low resistive pens along with resistive pens, looks pretty neat eg building circuits on the bus/plane/train or just prototyping stuff quickly
The pens are a little on the expensive side though around $13 - $20 range but looks like a lot of fun!
wingnut
Aug 9, 2012
255
I think the pens look a whole lot of educational fun.
It inspired me to pull out a pencil and draw 3 resistors in series on a piece of paper, (in thick pencil lines) and 3 resistors in parallel, put an ohmmeter across these, and the graphite acts as a resistor and so the resistance of resistors in parallel drops, while the resistance of resistors in series rises.
Next time I have to teach electricity, I will get the students to draw the resistors in thick pencil in their books, and measure the resistance of our graphite resistors. Graphite has high resistance in such a thin layer, so set the multimeter to mega-ohms .
And you can draw capacitors if you use both sides of the paper!
cjdelphi
Oct 26, 2011
1,166
With the pencil i used it to create a variable resistor for an LED, by moving a wire up and down the lead track..
However it was dim, so i connected the other end of the track to the base of a transistor or at least i think i did (tried many years ago) so i might have just dreamed up the transistor but it should work :)
wingnut
Aug 9, 2012
255
With a BC547 NPN transistor and 1K on the base, a LED connected to the collector via a 150 ohm resistor will light up even if one has 6 inches of graphite track.
So with pencil graphite we have variable resistors (cjdelphi), a capacitor using Bob's suggestion, conductors, switches (if one folds the paper over. And for teaching just add a transistor with a LED and they can see the resistance change from the brightness of the diode. I just wish there was some kind of conductive glue to stick the transistor to the graphite tracks. I did try stapling the leads to the graphite tracks, but it does not make contact.
One does not even need a transistor. Just use one LED with no resistor since the graphite acts as a resistor, and the brightness of the LED will show the varying resistance with the varying length of the tracks.
