Hi, How can I make electronic resistor thanks...
L laydinata Oct 28, 2005 12 Joined Oct 28, 2005 Messages 12 Nov 5, 2005 #2 Hi, How can I make electronic resistor thanks...
ante1 Jan 24, 2004 4,136 Joined Jan 24, 2004 Messages 4,136 Nov 5, 2005 #3 May I ask first; what you are going to use it for? And second; some data Watts Volts Amps Ohms?
L laydinata Oct 28, 2005 12 Joined Oct 28, 2005 Messages 12 Nov 6, 2005 #4 Hi, I want to make oscillator that works 65 Hz between 255 Hz . It's frequency changes automaticly so I thought If I have a electronic resistor I'll change that oscillator's freq. Have you VCO osc schem?
A Alun Jan 1, 1970 0 Nov 6, 2005 #5 We still need more information, voltage, wave form? The VCO design on the LM358 datasheet might be what you want if it's a square or triangle wave you're after. Last edited: Nov 6, 2005
