Electronic System Design
mikecon
Jul 13, 2016
3
I studied electronics about 20 years ago and became frustrated with learning a bottom to top approach. In other words learning series circuits, parralel ciruits, amplifiers etc.
I looked for books and on the internet for a top down approach but have had no success.
I want to look at a complicated system which is broken down
Fact of life....everyone starts at the bottom insofar as knowledge is concerned.
14,319
You cannot design a system when you don't know your building blocks.
You'll need both skills.
Google "electronic system design book" to find e.g. this book.
Sunnysky
Jul 15, 2016
577
I've designed complex systems, but then we hired Technical Writers to explain it in block diagrams.
What would you like to know?
It all starts with Input/Output/Process specs with all the environmental specs that must be written then tested (DVT). This includes EMC,(compatibility, suceptibility) DFM, DFT Deign for manufacturability, testability, low cost & reliability)
A system spec is not much different than IC spec , it just will have higher level functions and you dont need the specify what's inside, unless there are cost reasons.
To me it seems the Op wants "what is inside" and how it operates.
Just not prepared to do the long haul of study that other have done.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
What is a "hnd" ?
hnd = HND = Higher National Diploma. A British equivalent of a trade school, attempting to prepare people for a career as a technician.
A goodly part of systems design is defining what is important and what is not so important and what doesn't even need to be considered. A powerful tool for this is the Kepner Tregoe problem analysis paradigm. Once the problem is defined, you can begin to use top-down system design tools. The top-down design method needs iteration (feedback) before a design settles down to something that can actually be implemented. Think about, say, building a tall building. You build from the ground up, but you design it from the top down.
Google and a good technical library will be your friend in learning systems design. Study the NASA program that sent men into space and to the moon. It was never clear sailing, and many mistakes were made along the way, but the problem and its solution goal was clear and well-defined. Or take a close look at how the Manhattan Project led to two kinds of nuclear weapons and pointed the way to a third kind. Or, closer to home, research the British (and later, American) effort to break the German Enigma coding machine. All of these are examples of systems engineering carried out on a national level. Look at budgetary considerations, personnel available to do the tasks, and timing constraints. These are just three of the considerations you need up front for systems design. There is an old saying in the engineering community: Quality, Delivery, Price -- pick two of the three.
mikecon
Jul 13, 2016
3
Thanks for the reply.
An example of what im after is something like the breakdown of a tv circuit. Once the whole circuit has been broken down into the relevant boxes each of the boxes can be broken down further.
At the moment im not interested in timing constraints or costs etc just the aspect of building a complex circuit.
I feel like i know most of the fundamentals of electronics. Its like having all the pieces of a jigsaw but then not knowing how to place together.
I can desighm an amplifier, filters;timers etc but i wud like to c a whole working cuicuit an work backwards.
I have been on google an was no help. Also there are no decent technical libraries around here
duke37
Jan 9, 2011
5,364
Where is 'here'? I pop 10miles down the road to Derby University if I wish to look up some technical stuff. Also, the county library will order books from the National Lending Library. Most libraries have dictionaries, you may be interested.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Oh, really? Did you not get anything from the links on this page?
Everything I ever learned about television became instantly obsolete and irrelevant the day American broadcasting switched from analog NTSC standards to digital. Fortunately by then I was long out of the TV repair business and doing other things. Doesn't mean I couldn't design a digital TV from scratch today, but why re-invent that wheel? Tell us what you want to DO. And leave out the excuses for why you can't do it.
Sunnysky
Jul 15, 2016
577
All the details can be supplied by a search engine with the "right" key words.
or a better answer is possible only with a better question.
