EMP blast - what would happen really?
JoeBloe
Too many see big voltage numbers and then assume massive energy.
Lightning, for example, has massive power but far less energy at a
strike location. It is why most all trees struck by lightning leave
almost no indication.
I have seen several trees that were split wide open from lightning
strokes. I have seen them aflame as well.
JoeBloe
The energy content of fields from a lightning strike are really quite
low.
Tell that to the NASA boys down at Cape Kennedy. (they would laugh
at you)
The stroke the launch pad got the other day was 20,000 amps and had
quite a long duration.
H
Homer J Simpson
JoeBloe said:
On 16 Aug 2006 16:43:52 -0700, "w_tom" <[email protected]> Gave us:
at you)
No shit. Most people who 'survive being struck by lightning' actually were
hit by induced current - sort of like the difference between standing NEAR
the tracks and standing ON the tracks.
_____ _ _
|_ _| | | | |
| | __ _ _ __ ___ | |__| | ___ _ __ ___ ___ _ __
| | / _` | '_ ` _ \ | __ |/ _ \| '_ ` _ \ / _ \ '__|
_| |_ | (_| | | | | | | | | | | (_) | | | | | | __/ |
|_____| \__,_|_| |_| |_| |_| |_|\___/|_| |_| |_|\___|_|
__ ____
/ _| | _ \
___ | |_ | |_) | ___ _ __ __ _
/ _ \| _| | _ < / _ \| '__/ _` |
| (_) | | | |_) | (_) | | | (_| |_
\___/|_| |____/ \___/|_| \__, (_)
__/ |
|___/
JoeBloe
The whole reason that an ESD smock is used is for abatement of any
field a charged individual carries. There are components that are so
sensitive that even local electrical fields can damage them.
Otherwise all we would need is a simple wrist strap or heel strap.
The smock also reduces the amount of charge one builds as one walks
through the air in a room.
I have seen real demonstrations of the differences. It is quite
significant. Raw components that have not yet been installed are the
most vulnerable.
This is also why there are differences in the types of ESD packaging
"bags". The black, fully dissipative types are the best for most
purposes.
Richard Henry
purposes.
They really suck for carrying real-time-clock chips with built-in
batteries.
Chris Foster
My older brother, who is with the Navy, once brought home some, lesse
I have the datasheets, CK5703 and CK5744 type miniature (wire-lead,
T-3 bulb) single triodes. He said that, on the fighters (F-18ish) he
was working with, there are the normal systems, backup systems, robust
backup-backup systems, and at the very bottom, when all the hit shits
the fan...a handful of tubes so you don't completely drop out of the
air.
Tim
Not true. i worked on the F/A-18 at McDonnell Douglas for nearly 20 years.
The Flight Control System was a quad redundant GE designed fly-by-wire
system. If that failed, the pilot had a hydraulic backup. If that failed;
time to eject
Richard Henry
time to eject
As I recall it, the F-14 has two hydraulic systems attached to each
critical control surface, one powered by each of the engines, and a
backup electric pump to provide power for critical things like getting
the landing gear down. F-14 #1 crashed early in the testing process
due to total hydraulic failure
Richard Henry
time to eject
time to eject
No, um, electronics in the ejection mechanism, right?
Hoo boy... Grab sledgehammer, break canopy, crawl out of cockpit?
Michael
Leon
time to eject
I worked for Racal on military radio systems. A typical MoD spec. that
we worked to stated that the system had to carry on working after a
nuclear event, albeit at reduced performance.
Leon
K
Ken Smith
There wouldn't have to be. It could be made purely mechanical. The
mechanical workings would have to have a few springs and dashpots. You
want the canopy flung out of the way before the rocket under the seat is
fired.
There may have to be a gyro under the seat that gets spun up before launch
too. I don't think you can expect the pilots weight to be centered over
the thrust. Doing it all mechinically would technically be "rocket
science" but it wouldn't be out of the question.
Chris Foster
[email protected] wrote in
Michael
Nope. Purely mechanical tied to explosive bolts. Can shoot the pilot
right thru the canopy if needed.
JoeBloe
Yes, explosive bolts actuated by a mechanical force, as well as an
explosive propellant to actually facilitate the ejection process.
Rich Grise
I've seen this, except it was a maintenance man, and it not only shot
him and the seat through the canopy, but through the corrugated steel
roof of the hangar. The seat stayed on top of the roof, next to the
hole, and his body fell back down splat on the wing of the airplane.
A couple of months later the base safety officer went around to all
of the shops to give the summary of the accident report, and in a
nutshell, he said, "It's a bitch when you have to tell a young wife
with a new kid that her husband has just killed himself by his own
stupidity."
Rich
JoeBloe
stupidity."
He wasn't strapped in, nor at altitude, idiot. He was servicing the
craft. Not only that, but it may not have been "his stupidity". It
may have been accidentally initiated.
