Encoder TTL pulse train multichannel repeater
H
Haritztolete
Hello, I am working with a 5V train pulse encoder (Scancon), and I
would like to use this same signal in some different devices, four
tracking cards, two PLC's... Does anybody know if there is an
industrial commercial repeater to do it? The encoder has six signals A,
-A, B, -B, Io, -Io. I want to repeat these six signals in order to use
them in different devices.
laodao
If the signals' frequency is not too high, I think maybe RS485 is what
you want.
Chris
Hi, Haritztolete. You'd have to be a little more specific:
Encoders with 5V outputs usually have one of 3 types of outputs --
totem-pole (similar to a standard TTL output), open-collector (similar
to an open collector 7406-type output) or line driver. Since you
didn't specify the encoder, you should at least be able to tell that.
No matter which type of output you have, you might first check if there
are going to be ground loop problems. If you're going to four tracking
cards and/or two PLCs, it's possible they may be at different ground
potentials. If they're at the same potential, and they're all the same
type of input, why not just drive all four of them with the one encoder
output? And if they're at different potentials, you might want to use
optoisolation to avoid ground loops which might interfere with your
signal at best, and may destroy your equipment at worst.
To be honest with you, despite the almost monomaniacal insistence of
many people on only installing purchase parts, there comes a time when
the blivet box is a really good idea, and this looks like it might be
one of those. Assuming standard totem pole output/input, I'd just use
four 74C914s at the input (with small series resistor at the input, and
a 1K pullup if you've got an open collector output from the encoder),
and follow them with four 74(HC/LS)04s to double-invert and send the
signal out to your four destinations (or 7406s if you have current
sinking or opto inputs at the card). You can always use a fancy
connector and screen something on the blivet box to make it look
store-bought for the customer if required.
| VCC
| 1K | |(If O.C. Output)
| IN | ___ |\ |\ OUT
| o-------o-|___|--| >O--| >O-------o
| 100 |/ |/
| 1/6 1/6
| 74C914 74LS04
| (or 7406 if req'd)
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
After all, the customer has to buy it from somebody. Call yourself a
manufacturing company, sir. Your custom blivet box is now a
store-bought item. Voilla!
If your job absolutely requires something manufactured by someone else,
you might want to follow up with telling what type of output your
encoder has, what type of input your cards have, and whether there's
going to be a ground problem. Either that or better, try posting that
information at sci.engr.control -- they're the PLC experts.
Good luck
Chris
