Energy bands
Kevin Weddle
Feb 23, 2004
1,620
Doesn't it seem odd that the current in p type is within the covalent band while the n type current is in the conduction band. I would suspect a property difference in there somewhere. Copper has overlapping energy bands whereas it takes the same amount of energy to push an electron in the conduction band as in the covalent band. Does anybody know what the real meaning of this phenomenon is? Did you know that they are using n type silicon nails now for ICT. As if they can really be worried about that inductance.
While we're on the subject, it's also worth mentioning that atom with more electrons have lower energy levels than atoms with few electrons. This is because the core attraction of the protons pulls the electrons closer to the nucleus. This means that the required energy to push the electrons into a higher energy band is less.
Giuflex
Nov 6, 2004
14
U are wrong from the begining. it doesn't matter which kind of semiconductor U are using, the principle is the same: an electron passes from the covalent band in the conduction band if U give him enough energy to do that. At a normal temperature(18-20 Celsius) electrons inside silicon dopated with n or p type impuritues (and other semiconductor materials used in electronic active components) have enogh energy to jump from the covalent band to the conduction band. The defference between n & p types of silicon is the nature of the impurities unsed to create them. As I remember n type impurities give conduction electrons in the material. I suggest that U go to a library and borrow a book about semiconductors and electronic components made from semiconductors and read it carefully. It's hard to make a summary of such book. Enjoy your lecture!
