Equalizer ...
Mukhalled
Aug 17, 2004
137
Hi everybody
I need to build an equalizer ( with some diodes ) for my amp. Does anybody have a simple circuit ...  ;D
audioguru2
Apr 6, 2004
12,026
I think he wants us to translate his request.
"Diodes" are probably LED arrays that indicate signal strength at the same frequencies as the equalizer, you know, a real-time-analyser.
An equalizer plus a real-time-analyser certainly won't be simple.
If he made them, then the equalizer would probably just overload his amplifier and speakers anyway. :(
Staigen1
Oct 26, 2003
695
I assembled a kit a few year ago, for a friend, i belive he ordered it from germany, a realtime analyser, a simple one, it was based on a few IC:s and, if i remember right, 100 Leds, or was it 200. It was suddenly not an easy project, with surface mount components and all! And that was only the analyser.
//Staigen
audioguru2
Apr 6, 2004
12,026
You can purchase an equalizer with built-in real-time-analyser fairly cheaply. They are mass produced by robots.
If you make one yourself then about the only thing with a discount for quantity are the LEDs. :(
Staigen1
Oct 26, 2003
695
No, i'm not gonna build one, it was Mukhalled who was asking for simple circuit...
//Staigen
Mukhalled
Aug 17, 2004
137
Hi guys
thank you for answering me. Sorry I meant LED "Light Emitting Diode" not just Diodes
Staigen1
Oct 26, 2003
695
Hi there again Mukhalled :), nice to see you
Well, a kit would not be that complicated, i belive. Try it, if you can find one :)!
I completed one a few years ago, as i say, and it was not that hard to do.
//Staigen
Mukhalled
Aug 17, 2004
137
Yes I'll try and I'll do my best  :)
Thanks Staigen to encourage me, I appreciate it  :)
Best Regards,
Mukhalled
Staigen1
Oct 26, 2003
695
Good luck, Mukhalled ;D
And keep the good thing going ;D
Keep on experimenting ;D
You learn a lot by your own mistakes ;D
And also by the thing that works ;D
And you have fun at the same time ;D
BTW, the amp you and Audioguru buildt, is it something i have missed?
//Staigen
samkay
Sep 3, 2005
u ve to go back and study the characteristic of what u need then e can easily get the component to use in buildng it  as a part
dont look at it as a whole
i think that will make it simpler
audioguru2
Apr 6, 2004
12,026
Hi Mukhalled,
Here is a very good article about how to make an equalizer, called a graphic equalizer. The same kind of audio filters can be used to make a real-time-analyser which is also called a graphic analyser. I don't think the author of this graphic equalizer has made a graphic analyser project yet. http://www.sound.westhost.com/project75.htm
audioguru2
Apr 6, 2004
12,026
Yeah, Mukhalled built the "22 Whats per channel amp" in our projects section then had a problem with distortion when he turned up the volume and bass. He learned from me that it really only produces a few watts into 8 ohm speakers and a little more into 4 ohm speakers when using his car battery to power it, and he was trying to make it produce much more. The post is here: http://www.electronics-lab.com/forum/index.php?topic=3784.msg23884#msg23884
My new car came with a 228 Whats Pioneer sound system complete with a 10" sub-woofer. The 6x9 speakers on the rear shelf are only 2 ohms each.
This system is much more powerful than the 200 Watts system in my old car. I calculated and measured my old system at 14 Watts per channel at clipping into its 4 ohm speakers which adds up to only 56 Watts total for its 4 channels.
I can't easily measure the power to my new sub-woofer because its amp is inside the sub-woofer. ;D
Mukhalled
Aug 17, 2004
137
Hi Audioguru and Staigen
Thanks for the article, I'll study it first, but I don't think that I will build it acually because my project (which I will do in school) is about audio amplification and the equalizer thing was just an additional idea.  :)
I wonder if Staigen has read our post about the amp  ;D, thanx for wishing me good luck  ;D
by the way, congragulations (Audioguru) for your new car with Pioneer sound system  ;D
Best Wishes,
Mukhalled
Mukhalled
Aug 17, 2004
137
Hi again my friends  :)
What can I do if I hear sound of the car-engine in the loudspeakers?  ???
;D
Alun
Turn up the volume and your engine will go faster because it sounds louder. ;D
No seriously, the problem is the spark plugs in the engine are generating electricla noise which your amplifier is boosting and delivering to the speekers, there are several ways to try to combat this problem but as EMC isn't an exact science there's no guarantee  that it'll work.
Does this nois occur only when you're listening to the radio or does it affect tapes and CDs as well?
If it only affects the radio then it's radiated noise so moving the aerial might even help to some degree.
If it's affects CDs and tapes to then it's conducted making an RF suppresser by adding inductors, ferrite beads and capacitors to the amplifaier's power supply leads might help.
In both cases suppressing the car's ignition system with ferrite beads, inductors and capacitors could help.
