John Larkin
- Jan 1, 1970
- 0
John Larkin a écrit :
I wasn't speaking of measurement instrument capabilities, I can easily
get down to the fF, but rather meant: how do you measure it without
introducing perturbations, i.e. field modification with your probe,
wire, whatever...?
At this pad size I guess you can't neglect this anymore.
The true test would be a check between a field solver and a careful
measurement, but we also need to accurately measure Er.
Not hard. Measure Er on a big hunk of copperclad. Now cut the test pad
and hook up the AADE meter. Ground one side and use a needle probe on
the other. Place the probe close to the pad, zero the c-meter, then
touch the pad. I've done this on small pads, and it seems legit to me.
As long as the c-meter reads about the same fairly far from the pad as
it does just before contact, which it usually does, this should be OK.
John
