Ethernet interconnection between two embedded PC's inside one box
Bert
I have a question about interconnecting two embedded PC's by Ethernet.
Our situation:
- PC A has the LXT9785 Ethernet PHY of Intel, internal termination,
with 1:1 transformer and 1nF/2kV capacitor at the TX and RX center
taps at the secundairy side.
- PC B has the 82562ET Ethernet PHY of Intel, termination near PHY,
without 1:1 transformer. The specification of this ethernet PHY
describes the use of a 1:1 transformer with a 75ohm in series with a
1.5nF/2kV capacitor at each center tap at the secondairy side.
Question: has someone experience with interconnecting Ethernet ports
of two embedded PC's without using a transformer at one of the PC's,
in our case PC B? What are the consequences, limitations or general
issues? The distance between these two PC platforms is apporx. 15
centimeter.
All suggestions are welcome.
Kind regards,
Bert
Our situation:
If both embedded PCs have the same potential (GND to GND = 0 Volt) and the
distance is "short" then:
*) You can drop both PHY and wire MAC to MAC.
If potentials differ or the distance is too long. Then you can:
*) Remove one magnetics transformer.
This ofcourse requires that all persons handling the equipment are aware of
this issues when handling units or expanding them. Ie a motor drive on one
of them may make the first solution unsuitable.
The second solution requires that the network wire isn't reconnected to any
other unit that is also unisolated.
donald
Bert said:
Our situation:
centimeter.
Kind regards,
Bert
Bert,
Can these two PCs connect to each other by a hub or switch ??
If so then a cross over cable will work just fine.
donald
JosephKK
Bert said:
Our situation:
^^^^^ Sounds a bit cheesy to me.
W
whit3rd
Much of Ethernet's cost is in the interface to that unshielded twisted
long wire.. You can omit transformers and such, but... why Ethernet
at all? Multiprocessor communication is usually through shared
(two-port) RAM, isn't it? Or even a pair of FIFO RAMs?
I'd either use a standard processor board with the full Ethernet
hardware, and treat the ports as useful for breaking out signals
for maintenance, OR go with a full-custom shared memory.
Bert
I understand that there arte better solutions for communication
between two PC's, but in this system we have not the opportunity to
chose another interface. Ethernet is the only available interface.
Thank you all for your suggestions !!!
