Ethernet to fiber optic converter
PRIYADHARSHINI
Feb 6, 2014
137
Hi
Can any one tell me the low cost IC to convert the Ethernet to fiber optics(TX,RX) ????
Thanks in Advance
ramussons
Jun 10, 2014
475
AFAIK, there is no "Single" IC for this conversion. You can get Modules for this.
Google for "ethernet to fiber media converter"
AnalogKid
Jun 10, 2015
3,058
There are many different Ethernet copper and fiber protocols and speeds. Which ones do you want to use?
ak
PRIYADHARSHINI
Feb 6, 2014
137
Hi all
I have chosen the AL210 for this conversion.I have doubts and I have posted my schematic and its datasheet.Can you tell me what things i have done wrong in the schematic.
1.Pin num 20 & 27..I don t know how to give connections.and i don t know what is the meaning of Reduntant Link?
2.In data sheet They have splitted Power supply as +V and 5v...Is for split the analogue and digital supply
or to split the supply for fiber?
3.SD (In datasheet It stated that the SD pin signal detect pin is inbuilt in the IC)
But I m using AFBR-5803ATZ ST fiber optic connector..But it has SD pin.where I have to give the SD signal in AL210 IC????
4.What is meant by Volage mode fiber optic and current mode fiber optic ???
Its quit confusing for me...Please Help me.
Thanks in advance
  • Ethernet to Fiber optic -SCH.PDF
  • AL210.pdf
