Arlet
- Jan 1, 1970
- 0
Nico said:Sorry, I just don't believe this. Every Weller magnastat soldering
iron I've used needed its tip replaced on a regular interval. After a
while the tip just won't wet properly at some locations and this gets
worse over time. If you use a big tip on big joints, this isn't a
problem because in most cases you can find a spot that will wet.
However when you use a very fine tip to solder 0.5mm SMT devices
you'll find the tip will go bad (become useless) very quickly! This is
why I throw out the Weller soldering stations whenever I can.
I don't know if this makes any difference, but the one I have is not a
magnastat. It's a WS-51 iron with a ETH tip. The point is about 0.8 mm
wide. I don't like the really thin tips such as the ETS, because they
get bent too easily, and the ETH tip works fine for 0.5 mm flat packs.
It still wets around the whole tip, without any bad spots.
