Eeyore
- Jan 1, 1970
- 0
John said:For audio, I wouldn't think that even a microsecond of RMS jitter
would be audible.
1 part in 200 ?
Are you joking ?
Graham
would be audible.
1 part in 200 ?
Are you joking ?
Graham
John said:I don't know if a microsecond would be audible, but I'm sure that
picoseconds can't be. Brownian motion pounding on a microphone
element, or on your eardrum, has got to wobble things more than that,
not to mention the s/n of the whole signal chain. Try quantizing the
effects of vibration of your walls as it affects echoes... you'll
easily get nanoseconds.
As I said, jitter doesn't raise the quiet noise floor; it just
extracts a bit of what signal energy is present, and spreads it around
the spectrum. You'd have to be able to hear that low-level grass
scores of dB below the instantaneous program material. The paper cited
here misses this entirely.
It sets 0dB actually AIUI.
I'd be surprised that Julian missed anything.
Let's take your example of 1us. With 48kHz sampling that represents an error of 1 part
in 200.
Since the 'reconstructed audio' can be seen if you like as 'join the dots' puzzle and
those dots are placed according to voltage and time, it doesn't take too much to
realise an error in one can be seen as broadly similar to an error in the other. The
two effects can be transposed.
With a random distribution to the jitter, that would be like a s/n ratio of a mere 46dB
Jitter in the tens of nanoseconds range is considered quite poor btw. Hundreds of
picoseconds is considered good.
John said:What's that word you like... eh? 1 usec is 1 part in 21 of the period
of 48K.
But that isn't the point. If the program material were 100 Hz, 1 usec
timing errors would result in minute amplitude errors.
If it were 10 KHz, the errors would be a lot bigger. It's the signal frequency that
matters here, not the sampling frequency.
Even if the s/n is 46 dB, could you hear -46 dB of random noise
*** while the signal level is 0 dB? ***
Considered by whom? Audiophiles? The same guys who argue about burning
in and cryotreating RCA cables?
Silly me. I slipped a zero. Not sure how I managed that.
Who said it was anything to do with amplitude errors ? What's 'minute' btw ?
I don't see any supporting analysis.
