Ken,
I have the Version 10 programming manual. It makes no mention of the GEM-X10 or the relay board. I also have the most current
version of Napco's "Quickloadr" programming software. Under the P816 there is no screen for configuring a GEM-X10, an RB1000 or an
RB1008.
It is possible that something has changed and that I've missed it. Like Jim who is also trying to assist you, I mainly used Napco's
larger panels. However, I spoke to a Napco tech support rep and he said the panel won't support it. One fellow here insists it
will and it is possible he's right. However, I'd strongly advise you to confirm the panel will support it before you buy anything.
I sell Napco to DIYers but I would not offer you the board unless we first confirmed it was going to work. I can confirm that Jim
is correct about relay control. Napco's panels see the GEM-X10 as if it was an external relay board. They won't dim or do "scenes"
but they will turn devices on or off at preset times or upon various conditions and events (alarms, arming, disarming, zone status
changes, trouble conditions, etc.).
I've used Napco's external relay boards to do all sorts of things, including fully automating alarm systems for use in Orthodox
Jewish synagogues, performing basic access control of door locks, etc. You can do a lot with the larger panels. Until we can get
Napco to confirm the P816 is compatible with the GEM-X10 module though, Isuggest you hold off on buying one.
Regards,
Robert L Bass
Bass Home Electronics
941-925-8650
4883 Fallcrest Circle
Sarasota · Florida · 34233http://
www.bassburglaralarms.com
- Show quoted text -
