Fan problem in car
Matt
Does the fan in a car use a relay?
I have a Mitsubishi Sigma and most of the time the fan doesn't turn on
when I slide the switch and occasionally it will work. I have checked
fuses etc. Not sure if there is a relay problem or something else.
It is getting hot here in Melbourne and need the air conditioning! :)
Matt...................
Matt
Forgot to add that the airconditioning part uses a relay to switch the
seperate fan on in front of the radiator.
Matt.
Trevor Wilson
**Spend 30 Bucks and buy a manual. A schematic will be included.
BTW: Without including FAR more specific information (such as year model,
etc) no one can help you.
Dee
sounds like a faulty switch, pull it apart and give it a good cleanup
Matt
1983, Sigma GL GJ 2.6 litre, 4 cylinder Astron engine, wagon, rallyt
blue colour, standard rims, very little rust, clean engine area, good
interior, standard roof rack, tail pipe chrome tip.
Anyway, I do have a Gregory's car manual made for my car and I think
it has the schematic, so I will see and look at it. Wish me the best
to understand it.
Thanks for suggesting the manual. Never thought of that.
Cheers,
Matt..................................
Matt
OHHHHHH no please don't tell me to pull the dash to bits???? :)
sideshow bob
i have frends with the same
prob and trying to figer that out as well.
Matt
I don't know what the heck it would be. AFAIK, there isn't a relay to
control the blower, only for the air con. Maybe the switch has had it
but that seems fine. I might check some motor connections but that
will probably be a waste of time. Baffled.....................
Btw, no way I am calling an auto elec. Man they'd charge me 200 bucks
just to park it at the joint.
Matt............
Trevor Wilson
**Better.
to understand it.
**It seems you need another manual. I have a third party manual, for my
Commodore and the schematic section is complete, concise and easy to read.
Rod Out back
Matt,
Had a similar problem in our UD truck the other day with the fan for the
aircon. It turned out to be the fan motor itself was getting dodgey.
Sometimes the unit would start when the switch was turned on, but other
times it wouldnt do anything. Turns out the fan would fire up if you could
turn it a little. I would assume this is something like contactors in the
fan that were getting tired. A bit hard to spin the fan every time it
wouldnt go, as they are well encased in the ventilation ducting...Anyway,
the fan replaced with a new unit, and it works every time the switch is
turned on!
Just a thought; try pulling out the fan and seeing if it will start every
time you apply power to it. If not, try turning it a little to see if it
will then go. Thats how i worked out it was the fan for ours.
Just a thought...
Cheers,
Rod.......Out Back
Q
quietguy
Same happened with my Magna - pull the f'in dash out? Na, just fiddle with
it and with luck it will arc enought to set the bugger on fire
David
Q
quietguy
Must be catching
I have a problem with the fan in my Toyota - bloody mice get in - die when
I hit the fan on for air conditioning - and stink like hell for the next
week or so - but thats not the worst - their body unbalances the fan and
vibrates like hell. Mongrel job to pul the sucker out (I suspect as I've
been too bloody lazy to do it)
David
Roger Lascelles
Rod Out back said:
Matt,
turned on!
This is very true of older cars. The motor commutator or brushes wear out
and the fan won't start in all positions. Later, it stops altogether.
The wiring is not rocket science. Turn on the fan (ignition may need to be
on or even engine ?) and see if you have 12V at the fan wires. If you don't
have 12V, you may not want to check all that elderly wiring - just cut the
wires and connect your own switch to provide power / earth.
The Sigma is the right age for wiring troubles. Oxidation causes the
connector wire crimps to lose contact. The spade connectors get weak and
oxidised. Wires even corrode inside the jacket. In particular, I like to
wire the ignition separately with my own wire. Another trick is to
disassemble every connector in the car, file the wire ends in the crimped
connectors then solder. Makes lights brighter, starting easier, wipers
faster !
Roger
Q
quietguy
I suppose you've already hit the sucker with a can of CRC?
David
chris
near the fan is a bank of 3 ( from memory) resistors that controll the
speed of the fan...
a m8 had one of the sigmas... lol shit box..
his failed and would only work on high.. maybee start there
cheers
Matt
speed of the fan...
cheers
Ok thanks. I love my Sigma!
chris
my m8s sig was lowered with a stage 3 cam and extractors... got us into the
corner country no probs at all....
