Phil Hobbs wrote...
I'm a big fan of the MAX900 and brethren. Besides being a quick and
well-behaved part, it has a latch input that you can drive from its
own output. What's useful about this is that it gives the effect of
AC hysteresis but without putting junk back out the inputs. Bipolar
thresholds, window comparators, and so on benefit.
I agree, and have been a long-time user of the MAX903. In fact it
was the 3.5V TTL output of that '903 and most other LT1016 / LT1116
variants that set me off on a search for a different part. :>)
OK, so far we have several suggested comparators, all available in
8-pin surface-mount packages. All have input ranges that includes
the negative supply rail and can operate from a single 5V supply.
Most parts have a pair of complementary outputs, which reduces
supply noise, although two ICs address this issue with a separate
Vcc pin for the logic output stage. Two types are dual comparators.
Three types have rail-to-rail output swings. :>)
part speed Vo+ I_b Vo P_d latch hyst comp other
number (ns) (V) (uA) (mV) (mW) ? ? out? features
MAX903 8 3.5 4 4 18 X = X self-latch
MAX9013 5 3.3 + 5 4.5 X X X
MAX9012 5 3.3 + 5 2.4 - - - dual comparators
LT1116 10 3.4 10 3 135 X - X
TL3116 8 3.9 0.7 3 63 X - X
AD790 40 5 2.5 1* 50 X X - sep. logic Vcc
EL5181 8 5 3.5 3 40/55 X - - sep. logic Vcc
LT1720 4.5 5 <6 4 20 - X - dual comparators
notes
+ bias I_B = 2uA ?, or = 0 if Vin well above Vee, say > 1V...
* AD709K version available with Vos (max) = 0.25mV (miniDIP only)
Any other contenders for the list?
- Win
whill_at_picovolt-dot-com
