Favorite part, Low VF diode, low leakage
  • Thread starter Klaus Kragelund
  • Start date
K
Klaus Kragelund
Hi
I am working on a forward converter and are into optimizing the diode losses.
Sofar the BAT720 has proven fairly good, but would like to get even lower losses.
So, when the PIV is 20V, I found the DFLS130:
http://www.diodes.com/datasheets/ds30445.pdf
Has really low VF, but one gain seldom comes with a penalty. It has high leakage current at elevated temperatures.
Anyone got a hit for a nice part?
Klaus
Joerg
Klaus said:
Hi
No chance to use a FET and control the gate for an active rectifier?
Even if that's only for 80-90% of the conduction time that has gotten me
out of a pickle a few times.
K
Klaus Kragelund
What's the output current and voltage?
If this a push-pull, transformer-coupled, CT secondary, 2-diode
rectifier driving a filter choke?
Forward converter, 2-diode driving output filer. Current is 40mA, PIV is 30V
I am running it quasi resonant
Regards
Klaus
K
Klaus Kragelund
Yes, I have tried with sync rectification, self driven. Increases efficiency by 1%. Trouble is at that low current the gate charge for the FET takes almost as much that is saved in lower loss from the FET RDSon versus diode.
Regards
Klaus
K
Klaus Kragelund
Also, using self driven sync FET, I cannot use cycle skipping to remove standby losses, since the FET gate in uncontrolled when the switching stops
Regards
Klaus
