fax machine
lovetechnology
Jul 18, 2009
If this isn't the correct place, no doubt I will be told. Here is the situation. I have a fax machine that has decided not to work right. What happens is the power, xmt/reserve, and memory/multifile diodes light when the unit is turned on. Opening the compartment for the thermal paper roll doesn't result in the usual beep. You have to understand it is an OLD unit. Also pressing the usual buttons also doesn't even give beeps. The top row in the display only shows the squares.
Remember I said the unit is old. How about a cooling fan that comes on when the unit is in use. Along with an actual three ring binder for manual.
Hero999
Oct 28, 2007
2,433
Posting the make and model number might get you some helpful replies.
I doubt it though.
eduard0476
Oct 23, 2009
14
Hey just simple tips for your fax machine... just reset to the configuration settings you done... after you reset all turn off and on again... just first you do...
