FBI XL-2T
Recently I bought a FBI XL-2T alarm system. I installed it correctly.
But I no idea how to program it. I read thru the instruction
manual........ nothing workout sofar. Can anybody help me on this
please. I am looking for thge information like very detailed & A-Z.
Thanks in advance.
Slim
Rlb is a monkey that can program alarm panels. gonna take a lot of bananas,
though.
Jim
Thanks in advance.
Not to be nasty or anything, but I think that this is just about the
easiest panel in the world to program.
However, that being said, the simplest and most detailed information
you can get on it is directly from the programing section in the
manual. I don't think it can be expressed any more basic than that.
Robert L Bass
Slim said:
RLB is a monkey that can program alarm panels. gonna take a lot of
bananas, though.
Naah. Programming help is free. No bananas required, but I've never
gone ape over FBII panels.
Regards,
Robert L Bass
Bass Home Electronics
941-925-8650
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Well I programed it have way. I can arm & disarm it. So if anything
happened the siren makes noise.I want to know some detail information
about to program it to call upto 4 phone #.
F
Frank Olson
It will call any number you program into it. It will expect to hear a
special high frequency tone and then transmit the alarm or trouble code.
It will then expect another high frequency tone (called the
"kiss-off") and hang up. If it doesn't receive the special tone (you've
programmed it to dial a telephone number that doesn't have a central
station receiver on it), it will hang up and try again. It will keep
doing this for a preset number of times (I believe the default is eight)
and then the keypads will go into "trouble". They will display a
communication fault that you can only reset by powering the system down
and then back up again. If you DO program it to dial your cell phone,
you'll see your home phone number come up on your call display. When
you answer it, you'll hear "dead air" (the panel is waiting to hear that
special tone). When you hang up, the panel will dial your number again.
It will do this for the preset number of times. You won't be able to
tell whether the panel is calling in a system trouble (like a low
battery), a fire alarm, or an intrusion.
Quit trying to be a "cheap prick" and call a local alarm company to have
your system professionally monitored! :)
Crash Gordon
Or learn to whistle at the correct freq. for the handshake and
kissoff...then learn Alarmglish to interpret what message it has to send.
It ain't rocket science just a failure to communicate.
Crash Gordon
-------ouch------
<I feel like I'm diagonally parked in a parallel universe>
F
Frank Olson
It *is* rocket science. And "failure to communicate" is something Bass'
customers frequently complain about. :)
Crash Gordon
sot: What's the handshake freq. with CID, do you know off-hand?
Got a buddy who's gonna try this same stupid thing and Vista 20p's not gonna
dump the communication failure unless he powers down...so I know I'll get a
phone call on Wednesday! I know I know, but he's stubborn and he wanted to
try it anyway!
Crash Gordon
-------ouch------
send.
F
Frank Olson
try it anyway!
1400 or 2300 Hz... I think most receivers will send both. I believe
that's standard for most receivers, but Mark would be in a better
position to answer that. 1600 Hz is a non-standard tone that's used for
export versions of some of the DSC "Power" products.
Crash Gordon
ah, forgot to try that...yah that should work.
or teach him to whistle at 1400/2300
kinda dumb you can't clear the com fail with the master code + off or
something along those lines.
Crash Gordon
-------ouch------
| You could always enter then exit programming, that'll clear it up.
| gonna
get
| a
| to
| > try it anyway!
| > Crash Gordon
| > -------ouch------
| message
| > send.
Bass'
Crash Gordon
It should dial your cell, but it will just ring and you'll hear dead air
most likely since you cant give the handshake.
If it doesn't ring your phone, check your programming and wiring to the SNI.
Crash Gordon
-------ouch------
|I didn't get anything guys......
