To fully meet the growing demand in the AIoT market for high performance, robust computing power, and low power consumption, Forlinx Embedded presents the all-new FET3576-C SoM, developed based on the Rockchip RK3576 processor!
Integrated with 4 x ARM Cortex-A72 and 4 x ARM Cortex-A53 high-performance cores, featuring a built-in 6 TOPS powerful NPU, the FET3576-C SoM empowers your AI applications. With a board-to-board connection design and plug-and-play capability, it facilitates easy installation and maintenance for your products.
The product undergoes rigorous testing at Forlinx Embedded Laboratory ensuring stability and reliability for your products. With a 10-15 year life-cycle, it assures continuous supply.
FET3576-C SoM release marks a new milestone in the collaboration between Forlinx Embedded and Rockchip. As we enter the era of mobile intelligence, we are committed to working together to provide customers with excellent products and high-quality services.
01 Eight-core High-performance Chip with Advanced Video Decoding Capabilities
RK3576 is a high-performance, low-power application processor designed by Rockchip specifically for the AIoT market. It features four ARM Cortex-A72 cores and four ARM Cortex-A53 high-performance cores, along with a built-in 6TOPS powerful NPU for advanced computing tasks. Additionally, it includes an embedded 3D GPU, a dedicated 2D hardware engine with MMU, and H.265 hardware decoding, supporting up to 8K resolution for enhanced display performance.
02 Firewall Achieves True Hardware Resource Isolation
RK Firewall for managing access rights from master to slave devices and memory areas for true hardware resource isolation
03 Supercharge Your AI Applications With 6TOPS Computing Power NPU!
RK3576 processor is equipped with a powerful 6TOPS NPU, supporting INT4/INT8/INT16/FP16/BF16/TF32 operations. It can operate in dual-core collaboration or independently, facilitating multitasking and parallel processing across various scenarios. It supports multiple deep learning frameworks such as TensorFlow, Caffe, Tflite, Pytorch, Onnx NN, and Android NN.
04 Ultra-HD Display + AI Intelligent Repair
RK3576 processor supports high-definition H.264 and H.265 encoding/decoding, and features five display interfaces: HDMI/eDP, MIPI DSI, Parallel, EBC, and DP. It enables triple-display setups, 4K@120Hz Ultra HD display, and super-resolution capabilities. Intelligent image restoration enhances blurry images and improves video frame rates, meeting diverse display requirements across multiple scenarios.
05 FlexBus New Parallel Bus Interface
FlexBus features a flexible parallel bus interface capable of simulating irregular or standard protocols, supporting 2/4/8/16-bit data parallel transmission at clock speeds up to 100MHz. Additionally, it includes a rich array of bus communication interfaces such as DSMC, CAN-FD, PCIe 2.1, SATA 3.0, USB 3.2, SAI, I2C, I3C, and UART.
06 Continuously Updated User Profile
Comprehensive resources including carrier board schematics ensure simplified development and streamlined production processes for you.
07 Wide Range of Industry Applications
Forlinx Embedded FET3576-C SoM is versatile across industrial, AIoT, edge computing, and smart mobile terminals. With Forlinx's robust technical support services, accelerate your product's time-to-market and seize the lead in your industry.
Carrier Board
OK3576-C Development Board
To minimize your development workload, we can provide starter kits that can be used as complete development platforms for evaluation and application development.
OK3576-C Single Board Computer by Forlinx is powered by Rockchip RK3576 processor, featuring 4x ARM [email protected] + 4x [email protected], 2GB/4GB LPDDR4 RAM, and a 6TOPS NPU. It employs 4 100-pin board-to-board connectors to easily access all processor function pins, offering seamless functionality and ease of customization, and supports Linux 6.1.57 system. Featuring open system architecture design, it can provide technical information for your secondary development.
OK357
Carrier Board
OK357
