How to manipulate formula for values as necessary for spark time , so as can get back EMF from inductor greater than 100v , when spark time is to be 34% duty cycle of 360 degrees flywheel turning, using 6 amps DC, inductor time extension, 20 initial volts DC, Spark as only from inductive type ignition. The AI computer recently gave sample formula that said 100v output as from 11.11 milliseconds fast discharge, - but probably won't match the required 34% on time of spark. The sample inductor 1.5Millihenry charges , fires forward , then sends back EMF to output also using side diode guide, after polarity reversal. to the same output. V = L * (di/dt) * t. Some values need to be changed so as circuit matches for TDC ignition firing to 34% on before spark cut off.
