F
[email protected]
- Jan 1, 1970
- 0
Dear ng,
I want to ignite a short arc lamp (HBO100) which basically is a sparc
gap in special athmosphere. For ignition high voltage (~2kV) and low
current (few mA) is needed, and for operation low voltage (20V) and
high current (5A).
Now I have some hv sources (simplest is a piezo from an old lighter)
that make the lamp spark when no psu is connected to the lamp. If
additionally a PSU (current regulated lab supply or battery with
resistor in series) is connected to the lamp, no spark occurs in the
lamp.
Obviously the spark ends up in the psu/battery. Now I assume a low
pass filter should do the trick, specifically of LC type, since I
expect in an RC low pass filter the spark would just be dissipated in
the filter resistor (or not?).
The rise/fall time of my ignition spark presumably is extremely short
and the voltage is rather high (about 8 kV) so that the dV/dt is
extremely large and I'd expect the coil in the LC filter to just
`block`the voltage pulse in this simple setup:
+20V----L-(R)--------------------
(C) arclamp hv source
-20V--------------------------------
(I hope the ascii art is readable)
However, it doen`t work for any coil I used (ferrite core with up to
200 windings).
Probably I miss something here. Can the coil be too large (given low
R) or has it got to be much bigger (sorry, I don't know the exact
inductance)? How important is the dimension for the capacitor?
Any suggestions?
Thanks a lot,
Mathias
high current (5A).
lamp.
200 windings).
Any suggestions?
Thanks a lot,
Mathias
