find phasor current
Ledwardz
Dec 21, 2010
43
Hi, we have been given exam papers to revise from with no solutions....... yes i know its stupid and means i don't know if what i am doing is right.
ive attached the question and here is my answer
4.46A with a phase angle of 30.38.
but if im doing it wrong i need to know........
my working is as follows:
Vt = 25v to angle of 53 + 33v with no angle
= 58v to angle 53
The magnitude of impedance = 13 (square root of 5 +12 squared)
the angle of impedance = 22.62 degrees. (arctan 5/12)
then i = V/Z
so i get 4.46 < 30.38 A
if any one could confirm that id appreciate it. Thanks, Lee.
barathbushan
Sep 26, 2009
223
The whole method of solving the problem is right and the calculation of IMPEDENCE is also right , but the voltage computation is absolutely
wrong !!
i wont re-solve the entire problem , but i will tell you that , you just cant add the voltage magnitudes and angles like you have done , as it is clearly shown here
http://answers.yahoo.com/question/index?qid=20090421045522AAnABsZ
so learn your complex algebra well , and you will be able to tackle such problems
Ledwardz
Dec 21, 2010
43
soo
i should get Voltage = (58cos53 + j53sin53)
and impedence = (13cos22.62 + j13sin22.62)
then i got rid of sin n cos
(34.9 + j46.3) / (12 + j5)
then multiply by complex conjugate (12 - j5)
which = 3.85 + j2.25
magnitude = 4.46
angle = 30.3
so answer = 4.46 to angle of 30.3 A ???
Ledwardz
Dec 21, 2010
43
ahh crap i got same answer...... nm thats obviously wrong ill have another look. AHHHH.... i get it ha ha ha ha yeah okay u mean adding the voltages at the start is wrong h aha ha ha well i look like an idiot now. o well.
Ledwardz
Dec 21, 2010
43
okay ill try again
voltage magnitude = 52V
and angle = 22.6
I think that should be right?
barathbushan
Sep 26, 2009
223
no its wrong , let me give you the answer its
52.63<24.15 volts
one more method of solving the addition is converting both the voltages
25<53 and 33<0
to rectangular form , then add the real and imaginary parts
after that re-convert them to the polar form
use the above method is used if you have difficulty with polar form , but it's
not a good way to solve , please go through basic complex algebra
Ledwardz
Dec 21, 2010
43
i really dont know where i am going wrong as far as i am aware adding in polar goes something like this. i tried using example but exchanged the sin and cos for their actual numbers so when i squared it was easier.
=(25cos53 + j25sin53) + (33cos0)
= 15.04.. + j 19.966.. + 33
= 48.04.. + j19.966..
then magnitude is square root of em squared
n arctan for angle.
have i got it all wrong? It seems near the answer, maybe i have just done something stupid?
barathbushan
Sep 26, 2009
223
yes that's the answer just convert 48.04 + 19.996j into polar form , then you will get the right answer of 52.63<24.15 volts
magnitude = sqrt (48.04^2 +19.996^2 )=52.02
angle = tan-1(19.996/48.04) =22.56
ie 52.02<22.56 (approx to my answer of 52.63<24.15 )
