I need help to identify this Thermistor and find replacement
PJCP
Feb 22, 2025
3
This is a Xenon ignitor power supply made by ASTeX, EOL-175LR dated 2010. I was unable to locate either power supply itself or thermistor from the web. The thermistor itself has no any labels and the resistance measured is 1.3Kohm, diameter of thermistor manually measured is 17mmx5mm.
I wonder the one in the pic is no longer manufactured. TDK EPCOS PTC thermistors look similar but I could not find exact one with same specs.
PJCP
Feb 22, 2025
3
I have couple of experience replacing the thermistor fixed ignition problem - the thermistor was taking from a known good power supply which is no longer available. I want to spare thermistors for feature use.
They're all diffrerent, both in resistance and type and power handling.
PJCP
Feb 22, 2025
3
It will be highly appreciated if someone can help me with it. Thanks in advance!
Delta Prime
Jul 29, 2020
2,991
You’re welcome, prematurely.
Unsolder that thermistor. I think I see writing on it. Take a photo of both sides. While unsoldered get your multimeter out, measure the resistance note that resistance then take a hairdryer pointed towards the thermistor if the resistance decreases while heated, it has a (NTC ) negative temperature coefficient the reverse is true If the resistance increases, it has a (PTC)positive temperature coefficient.
Given the specifications of the equipment you took it out of, you can use it again on equipment with the same specs.
m3chunga
Apr 3, 2025
Hi PJCP,
It is a 1000-Ohm Thermistor. It is used on the SS-200 and SS-400 Xenon Lamp Power Supply on a Woollam System. Here is an alternative part number from the OEM.
Part Description: THERMISTOR, PTC, 480 VOLT, 1K OHM
MFG PN: PTCEL13R102SBE
MFG: VISHAY
MOUSER PN: 594-PTCEL13R102SBE
Hope this help!
Matt
