finding a suitable SSR
fetmosfet
Dec 7, 2014
5
Dear All,
I am working on a circuit where i use 5V from my digital pin of arduino to control a 12 Circuit. The 12 V circuit would have max current of 500mA. I would like to know a Solid State Relay (SSR) that I can use for the switching.
I would not use a normal relay as i want quick and frequent switching.
I tried using Mosfets, but it just heats up too much and also that I would want an NC too possible with SSR.
Kindly suggest me an SSR for both NC and NO.
Thanks in advance!
Have a nice day.
solid state relays are only available as NO.
Mosfets may be a better solution. If they were getting hot then you were probably doing something wrong. Perhaps you can explain your application a little better.
What are you switching (voltage, current, and type of load) and how quickly do you want to switch it?
fetmosfet
Dec 7, 2014
5
Thanks steve for the reply.
My application might seem a little weird but i am sure it will work.
I am using Max7219 multiplexing IC with arduino but this time to drive 64nos. of 12V LEDs.
Driving normal LEDs is very easy and I have done it a lot of time, but to drive 64 nos of 12V LEDs power supply becomes an issue for me. I intend to make an 8x8 grid as i would do with normal LEDs, Then connect 8 SSRs to segment points and 8 SSrs to Digit points.
Important thing i noticed is Digit points are always high and the LED Cathode is attached to it, so it lights up when the Digit points go LOW. Here using a Transistor or a MOSFET becomes difficult for me. I can easily use a Transistor or MOSFET on the Anode side of LED, i.e. the Segment side.
I then think that an SSR could be a solution as t=I can connect it to any side, anode or cathode.
Hope you understand my explanation.
Sorry if all this seems weird.
Other solutions are also appreciated.
You use N channel mosfets (or NPN transistors) for low side switches and P channel mosfets (or PNP transistors) for high side switches. You may need to invert the outputs to properly drive the mosfets.
Maxim even publish instructions for you: http://www.maximintegrated.com/en/app-notes/index.mvp/id/1196
You will lose the ability to control the LED current using the 7219 though.
fetmosfet
Dec 7, 2014
5
Dear Steve,
Thank You very much.
This is of great help to me. I googled a lot and even youtube in this matter but did not get something of much help.
This link that you have shared with me seems really helpful and I surely will try and get back to you.
P.S.: your subtitles say Thermodynamics... I found it thought provoking to see that word in an Electronics Forum.
Glad to have helped.
You'll understand my sig if you hang around until the next crowd of over unity folk arrive. :)
