Finlux tv problem
Alexander87
Dec 26, 2022
I have a problem with a finlux 55-fub-7000 TV, when I open it I see the original finlux and then there is a black screen and the TV light is flashing. can you help me
dragon
Oct 31, 2022
248
it could be a morse code signal for what the error is. but definitely is an error output of some kind i wouldnt doubt.
it could be the count of flashes is what error it is.
kellys_eye
Jun 25, 2010
6,512
99% of the time a power supply issue. Either related to the PSU itself or as a result of an internal problem (commonly the backlight) developing a fault. Many internal faults can cause the PSU to 'shut down' and the flashing light is the only information you get.
14,487
agreed ... usually indicating that the PSU is just cycling trying to fire up and it cant because of a fault
either in the PSU section or a failure elsewhere is loading down the PSU
check for DC output voltages on the PSU board, sometimes the voltages are written on the board beside connectors etc
it's time for you to show photos of the boards ... well lit and not blurry
resize them to max of 1000x 700 and around 100kb each
