Flexible Shaft
Bremme
Oct 6, 2016
10
I have a flexible shaft and would like to have a buzzer telling me the max torsion has been reached.
I was thinking adding a small magnet and Hall Sensor at both end. This way, when the shaft is at rest, both sensors are aligned. When in action, this shaft becomes twisted up to ½ turn (180°).
My challenge is to have a buzzer turned on when the torsion reaches 180°, neither before nor after.
I was thinking using an EXCLUSIVE-NOR gate (4011 or else). When the shaft is not twisted (no force applied), both magnets (or their absence) result with the same levels (HH or LL). When the shaft is active (transmitting a torque), the two magnets are not aligned anymore. This results in different input s to the X-NOR gate so the buzzer can be turned on.
My problem is to have the buzzer turned on only after as much as ½ turn (180°) of torsion is reached and this at any speed. So, a time delay can’t be applied.
Suggestions are welcome, even a complete different approach. Thank you.
dorke
Jun 20, 2015
2,342
Your hand drawing skills are impressive:).
I don't know if it is feasible here,but maybe an optical approach may be simpler.
Using an "optical fork sensor" instead of the Hall sensor ,and instead of the magnet use a "light blocking attachment" bulging from the shaft (or a slotted disc type) .
Using two of those on the end points of the shaft (180° locations) will tell you precisely when you reach the desired point.
Logically an XNOR will not work here,you need to "logically AND" the result of the Ex-NOr with the B sensor being at 180° location.giving the expression (notA) AND (B).
kellys_eye
Jun 25, 2010
6,512
If you can suffer the noise, use two micro-switches operating off cams attached to the collars of the shaft connectors.
In the event of electrical failure you would still 'feel' the point of maximum torque as the clicks occurred.
Bremme
Oct 6, 2016
10
______________________
Thank you very much for taking your time to give me this usefull answer. I appreciate.
