Is this a recessed ceiling fixture?
Yes, it is. Those 1970's style swivel things with a brass finish. I
use a very long rod to reach up that high, with a suction cup on the
end of the extention that is moistened to grip.
Those build up heat and are hard on compact fluorescents.
At <20 watts, though? These are 65-watt-equivalent-lumen types, with
the standard shaped bulb outside for gripping correctly. The coiled
glass envelope, phosphor-rare-earth coated, is in the interior of that
outer glass, flatish surfaced bulb that fits my grip. The
incandescents were 65 watts apiece and must have generated a lot more
heat up there in years gone by (and in my comparison incandescent that
I placed there.)
For that matter, some compact fluorescents brag
about being specifically rated to use in recessed ceiling fixtures. Such
includes the 15, 20 and non-dimmable 23 watt ones of Philips SLS series.
Philips did say that the 25 and the dimmable 23 are not rated for use in
I'll look more closely. This switch I'm using here is a dimmer type,
too. This could be another confounding issue, in my case.
I can say where and when compact fluorescents appear to me prone to
short life:
Thanks.
1) When on-time is short. As I hear it, "standard conditions" for life
expectancy include 3 hours per start. So I expect a fair chance of short
life expectancy compared to incandescents in motion sensor lights,
closets, restrooms used mainly for short trips, and refrigerators.
We keep the livingroom lights on, usually with the dimmer set to full
(I don't often dim), for more than 3 hours a day. And usually, most
of it in one sitting (evening.)
2) Higher wattage CFL in small enclosed fixture, due to heat buildup.
These are as described above.
3) If the CFL is a problem-prone one, such as (according to my
experience) 25 watt spirals of GE and LOA brands made around 2001, LOA
45 watt ones, and LOA "Q-Lites" from the early 1990's. Also I have seen
"dollar store" ones have a significant rate of spectacular infant
mortality, as well as never achieving claimed light output (sometimes
low by a factor of 3) and sometimes not achieving stated color.
Getting these bulbs from Costco and they are branded as described in
an earlier post.
4) I hear of a few complaints of the Commercial Electric 42 watt spiral
dying young when operated base-up. I suspect the problem here is heat.
Could be, but I've cracked two from the living room ceiling lights and
looked at the electronics and used my nose. They seem unburned. But
I could do a better post-mortem than I have. Have to wait another
cycle, though.
I have other situations around the house with a single switch (no
dimmers) and several fixtures, where I can add to the testing process.
Some are one end up, some the opposite. I'll start keeping logs.
What first got me onto this whole thing was that I bought this place
and moved in, early 2002. When we took over, there were two
incandescents in the livingroom ceiling. I replaced it with a new
CFL, fresh bought because I had to look for those funny ones that I
could mount at such a height via this pole contraption. Later, that
very CFL went dead on me. The incandescent was still working. And it
was the one the prior owners had placed there. So I replaced it,
again. The next CFL burned out, too, before the incandescent finally
went. With two CFLs dead in the same socket, an incandescent still
running for some time yet, I began to have my very first questions
about it. (This period of time was, perhaps, a calendar period of two
years.)
Since then, I've found this experience in a few other places around
the house, as well. Not as clear, to me. But definitely where I have
replaced a CFL a 2nd time (meaning that I am _positive_ that the
incandescent nearby is lasting longer) before having to replace the
incandescent. Some of these are older incandescents (from the earlier
owner, some are ones I've had in boxes and used recently.) I don't
think I've purchased _any_ incandescents since moving here, so all of
them are made prior to 2002.
That was my motivation and my experience leading me to begin, for the
first time, to wonder about whether or not these things actually do
last as long as they say or if perhaps the incandescents last a lot
longer than they say. Thinking backwards on this, I have to say that
the CFLs I've had 'go bad' on me must have failed to meet their hours,
rather than the incandescents lasting so much longer than rated. The
CFLs are, looking at the packaging, rated for 8,000 hours. So that's
almost a full year of _ON_ time. And I _know_ for certain that they
failed in less operational hours than that. The incandescent in the
living room lasted perhaps two years of use after we moved it and I
don't know how long, before that. That _may_ be just about its rated
life, given our use. Or perhaps a little better, though I'm guessing.
But it is way below the CFL's rating.
It is turning out, I think, that perhaps CFLs are more limited in the
areas they can be effectively used, as rated. If you are saying that
some are rated for my ceiling use, and some aren't, this is something
I've never needed to worry about before regarding incandescents -- so
this is new information to me. And it complicates the buying process
for CFLs, while not complicating it for incandescents.
Interesting, though.
Jon
