Fluorescent light fixture problem
W
woodpecker
We bought a fluorescent light fixture at Home Depot for our kitchen
about a year ago. It uses 3 48" T8 bulbs. It stopped working (all
bulbs) a few days ago. I had one extra new bulb, so I tried replacing
each of the bulbs. That didn't work, so I replaced all of them. Still
not working. The only other symptom was that before it went out
completely, for a few days it occasionally quickly flashed off then
back on.
Any ideas as to what my next step should be?
Thanks!
Woodpecker
Arfa Daily
David Nebenzahl said:
Yes; replacing the ballast.
(Unless someone here knows some way of testing the ballast.)
But first, just make sure that power is actually reaching the fixture, and
that there are no intermittent connections internal to the fixture. *Then*
suspect the ballast ...
Arfa
David Nebenzahl
back on.
Made From Pears: Pretty good chance that the product is at least
mostly pears.
Made With Pears: Pretty good chance that pears will be detectable in
the product.
Contains Pears: One pear seed per multiple tons of product.
(with apologies to Dorothy L. Sayers)
Samuel M. Goldwasser
And, if it's an electronic ballast that isn't potted, could be bad
solder joints on its PCB, though at this point with it being totally
dead, something may have blown.
sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
