flyback driver circuit
vitom001
Aug 12, 2015
5
I'm trying to construct a simple flyback driver circuit using a single BU-508D transistor. In my circuit,
the base (pin 1) is connected to the (+) 0-48v DC input, the emitter (pin 2) is connected to pin 1 of
my flyback (HR 7839, http://www.donberg.ie/pics/h/hr7839.gif), and the collector is connected to the
neutral of the DC input and ground. For the flyback, pin 2 is connected to the (+) 48v DC input, and pin 8
to ground. When I run the circuit I can hear the flyback working but there is no output on the HV wire.
What am I doing wrong?
duke37
Jan 9, 2011
5,364
Show us a circuit. If looks as if the BU508 (npn) is upside down but then it shouldn't work at all.
Colin Mitchell
Aug 31, 2014
1,416
The transistor has to be connected as shown in the diagram and the waveform has to be suitable to get the transformer to produce a high voltage under fly-back conditions.
vitom001
Aug 12, 2015
5
I'm using a step-down transformer from the mains (230v, 50Hz) to 48v and a bridge rectifier for DC. Pictures of my setup are attached below. Note: if we count the pins from the transistor from left to right as 1-3, then 1 is connected to the positive DC terminal, 3 is connected to the negative DC terminal, and pin 2 goes to pin 1 on the flyback (diagram shown above). Pin 2 from the flyback goes to the positive DC terminal, and pin 8 goes to ground.
