TV's are doulble insulated a earth pin is only required when an appliance has a metal case.
Higer frequencies do mean more bandwidth,you can't modulate a 10KHz carrier with a 20KHz signal but you could modulate a 20MHz carrier with this 20KHz signal.
prateeksikka,
Yes high frequencies do mean short antennas but the antenna still needs to be on a very tall mast to achieve a long range. If you stand to a mountain you can see from 100s of miles and you can see a mountain from 100s miles away.
I don't mean to have a go but I've already answered your question about high frequencies, did you even bother to read my previous posts?
High frequencies are more prone to interferance and transistors and other components don't work very well at these frequencies, acept in infrared and optical band when LEDs and photo diodes work. - I'm not going to say this again.
