*Frame* Rate vs. *Refresh* Rate
Radium
Hi:
What is the difference between "frame rate" and "refresh rate"?
Is it best for the frame rate to have a frequency the same as the
power supply [60 Hz in USA/Canada, 50 Hz in Europe/Asia]? Is this true
even if the video is digital and played through a digital plasma
screen?
In digital video, how is the sample rate mathematically related to the
frame rate?
refresh rate?
Radium
Jürgen Exner
I am not aware that they are related in any way.
The highest frame rate of any DSLRs that I am aware of is 10 frames per
second on high-end Canon SRLs. According to Ct (which in turn cited sources
in Canon corporation) this frame rate is artificially lowered because at
many venues a higher fps rate is considered filming and the fees are
significantly higher than for photography.
On the other hand the only refresh rate that comes to my mind would be the
time until a flash can fire again.
screen?
Huuu? Where do you find a DSLR with a frame rate of 60 fps? That's nuts.
frame rate?
refresh rate?
Huuuu? What does digital video have to do with SLR cameras?
jue
That's really interesting... because I have a Canon Powershot A530,
and the manual (which is for both the A530 and A540) mentions that the
A540 can shoot 640x480, 30fps, and 320x240, 30fps.
My A530 can only shoot at 20 fps at 320x240 (or 10 fps at 640x480).
Using Nero's VCD Burning Tools, I was able to create a Video CD that
would play on my DVD player... video was a bit jerky, though.
Makes me wonder whether I should just get an A540 (smaller), or
actually buy a digital camcorder next time...
screen?
frame rate?
refresh rate?
jue
Alan
Hi:
One is how fast information frames come, one is how fast the screen is
refreshed.
screen?
Not really. It helps in reducing the visibility of hum bars if all three
are the same, but power supplies are way better now, so that is of little
import.
Yes, it is unimportant even if the video is digital and shown on plasma.
frame rate?
By an integer multiple.
refresh rate?
What makes you think it is?
Alan
Jürgen Exner
Well, but how many professional photographers are out there using a
Powershot for their work?
jue
Dr Hfuhruhurr
jue
That confused me too but look at where the question has been
crossposted and its obvious the OP is erm... clutching at straws for
an answer.
Doc
contrex
an answer.
What baffles me is how does he type wearing a straitjacket?
F
Flasherly
frame rate?
Twice. 24 to 48 for high motion film or field rates using two stops at
each frame. As applied interlacing, and apart from detail,
deinterlaced line rates are accountable for a multiple again twice
over to equal perceived smoothness.
refresh rate?
Depends on the digital video card capabilities and whether or not it's
limited to the vertical sync of the monitor. A monitor maximum sync
at 60Hz isn't going to help a card capable of rendering 100 frames a
second, so it's a parity function while within specification limits of
the hardware.
Tarquin Fin-tim-lin-bin-whin-bim-lim bus stop F'ta
Crayon in mouth. It's common practice. Apparently.
Doc
Alan Browne
Radium said:
Hi:
screen?
frame rate?
refresh rate?
Whatever the answer I wish you had not x-posted this to a photogrpahy group.
Stephen
frame rate?
For PAL television the field rate is 50 Hz and the frame rate is 25 Hz. For
NTSC television the field rate is 59.94 Hz and the frame rate is 29.97 Hz
(or more accurately 60 times 1000/1001 and 30 times 1000/1001 respectively).
Both PAL and NTSC use 2 to 1 interlace which means that each field contains
only alternate horizontal scan lines. So in "625 line" PAL with 576
horizontal active lines per frame, each field refresh contains only 288
lines. In "525 line" NTSC with 480 horizontal active lines per frame, each
field refresh contains only 240 lines.
When viewed on a large scale the sample rate for the picture as a whole is
the same as the field rate which is the same as the refresh rate, i.e. 50 Hz
(PAL) or just under 60 Hz (NTSC). Movement is generally perceived on a large
scale so it is seen as though it were sampled at 50 or 60 Hz.
Fine vertical detail (i.e. detail which goes vertically across the
horizontal scan lines) is only sampled once per frame, on alternate field
refreshes, so this has a sample rate of only 25 or 30 Hz, and can flicker
violently if there is too much difference in intensity between adjacent
horizontal lines.
Large LCD and Plasma screens use "de-interlacing" to avoid this, but this
has drawbacks because it has to either display one field for twice it's
original sample period (i.e. display a 1/50th second exposure for 1/25th
second) or start doing clever things like only doing this for fine details,
or guessing where the patterns of the image should be in the missing lines
of each field by examining the picture details from adjacent fields and
lines. Most large screens use the "clever" approach, but none of this
processing can be done perfectly and it tends to introduce lag, smearing or
exaggerate mpeg artefacts by freezing them on the screen for twice the
length of time they would be displayed by a CRT display which is not
de-interlaced.
Modern large screens also have to resample the whole picture from 576 lines
to the 768 lines of the display which inevitably reduces the resolution to
about half of 768. This is why standard definition looks poor on an "HD
ready" screen but looks virtually the same as 768 line HD when displayed on
a CRT at 576 lines from an RGB Scart.
Modern HD ready screens also use heavy edge sharpening to try and offset
their lower-than-SD resolution when displaying standard definition, but this
also exaggerates mpeg artefacts (erroneous detail information), which is
another reason why these artefacts are objectionable and intrusive on HD
ready screens, when they are barely noticeable on a CRT.
It is an unfortunate fact that, since most TV we actually watch is still SD
but most TV's on sale now are "HD ready" with poor SD performance, it is no
longer possible to buy a new TV which is capable of displaying the majority
of TV broadcasts properly. For most broadcasts we can only get proper
pictures on "legacy" CRT TV's which have a limited lifespan and cannot be
replaced.
Roderick Stewart
[etc]
Nice to see such a clear explanation. If only the programme makers understood
it so well.
replaced.
It's unfortunate that nobody is ever likely to see such clear HD pictures with
such a smooth rendition of movement as the ones that were being shown at trade
shows like IBC more than twenty years ago. The interlaced signals were derived
from Plumbicon tube cameras, subject to control by vision engineers, and
displayed on cathode ray tubes with no digital processing in between. For a
while I thought it a normal symptom of the approach of old age that caused me
to be cynical about the notion that "progress" always represents an
improvement, but since then its even closer approach has disabused me of this.
It seems a waste of money to keep buying ever newer, ever more elaborate and
allegedly innovative domestic television equipment while the quality of the
material available to show on it proceeds on its present downward spiral.
Rod.
F
Flasherly
replaced.
There's that feature incorporated into my brand, in their newest $2500
offering, four or five times a magnitude I alloted, as chipset
enhancements marketed by a name something along 'The Director's
Chair'. Besides an entropy factor in layered encoding, which
spuriously generate artifacts that do, generally, detract from the
source material, the onus is then shifted into chipset algorithms, as
best fit to be weighed to derive positive potential in marketing
enhanced perception as an object apart from, otherwise, artifices.
Software layering is similar to that end, and makes a nice testbed
when dispensing with the tuner and layering a digitally enhanced
signal directly through the computer and into the display unit.
Although rudimentary, apart from encoding options available, there's
nonetheless benefits. I first used software test-pattern programming
to attempt to adjust for optimal edge sharpness, very different, being
limited in a few set and discrete steps, from a range given to "dial
in" sharpness from an analogue or legacy CRT. What's interesting,
beneficial, is one of the software players, GOOM (from the ranks of
freeware distribution), which also offers sharpness, noise, and
smoothness filters. I've effectively then two layerings from
sharpness, having initially adjusted the set, as well as software
smoothness, and added noise. Noise is a textural effect, either as an
artifice induced by color, if not b&w, which adds a sense of fine
"grain" to substances, overall, which can be additionally set for a
degree of greater or less magnitude, as can all three layers.
Sharpness is foremost to my usage beneficial, although depending on
the source material, animation for instance, the other two settings
may be worthwhile considerations. Given refinement, I should hope on-
the-spur filter decoding will continue to develop with more to offer.
Ray Fischer
In a year and a half it will be moot as there will be no more of the
same old TV broadcasts. They will all be replaced with digital
signals, and probably of better quality.
Michael A. Terrell
I hope you don't write any technical documents.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
John McWilliams
Here's an interim solution if you have one of them new fangled HD TVs-
may not be possible on all, but on my 4 year old Sony 60" what I do for
NTSC broadcasts is to split screen, and size the lo rez broadcast down
to where it's sharpest. It's about equal to the rez. I'd get on a non HD
tv. The other screen can be tuned into something slow, such as baseball
or golf, or Planet Earth.
Michael A. Terrell
Piggy said:
Don't be wicked!....he knows his stuff.
He still doesn't know how to make a readable post. That was just a
mess. No paragraphs, and no white space to seperate the ideas.
The whole idea of technical writing to to quickly and cleanly allow
someone to read and understand what you've written.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
F
Flasherly
So do you. Well, least what I've come up with so far. :;
freeware - codecs
ACE Mega CodecS Pack 6.03 - Professional
Edition Media Player FilterS, Media Players (MM Classic)
and other UtilitieS. Also I added Authoring
ToolS for video watching, audio and video
processing. In Add-On Pack you can found
Authoring ToolS for content creation.
and/or
freeware- movie player
GOM Player includes many codecs (XviD, DivX,
FLV1, AC3, OGG, MP4, H263 and more) so you
won't need to install separate codecs for
most videos. For those videos that require a
separate codec, GOM Player will find one and
direct you to a place where you can download
open source version of the codec. That way,
you won't get stuck with unnecessary codecs
on your system. Play Broken AVI Files
(Patented) AVI files can't be played if the
index is broken, or the file isn't completely
downloaded. This is because index is located
at the end of the file. GOM Player's patented
technology enables users to view files with
broken index or that are still being
downloaded. Powerful Subtitle Support GOM
Player supports SMI, SRT, RT, SUB(with IDX)
files for subtitle. You can specify margin,
location, size, resolution, font and others.
You can also enable shadow, view ASF files
with subtitle, karaoke subtitle mode. You can
even synchronize subtitle and video if
there's any mismatch. Convenient Playlist GOM
Player supports playlist formats such as M3U,
PLS, ASX. You can include different media
types on a playlist. Also, it also lets you
edit playlists for different media types.
It's easy to create and edit your own
multimedia playlist with GOM Player. Support
Different Media Types Along with different
media format such as AVI, MPG, MPEG and DAT,
GOM Player also supports streaming Windows
media format (WMV, ASF, ASX). You can also
watch DVD-quality videos with 5.1 channel
audio output. Screen Capture Screen capture
allows you to take a screenshot of your video
directly from GOM Player. Using the Burst
Capture feature, you can take continuous
screenshots upto 999 shots. Advanced Features
There are other endless number of advanced
features. Customize brightness, contrast and
saturation. Sharpen and add noise to your
video. Try audio equalizer. Repeat a section
of your video with our A-B Repeat feature.
Fast forward/rewind a few seconds using
left/right keys. There are even more for you
to discover!
(...keyboard macro reassignment/additions, which aren't mentioned)
