Sony HC5E low frame rate in low light
Hello!
Why does a panoramic video (in an evening or inside a building, shot
by Sony HC5E camcorder) look like the frame rate is about 10 fps? My
11-year old JVC VHS-C camcorder never had this problem, the video was
always fluid.
Best regards,
Dima
ransley
Hello!
always fluid.
Best regards,
Dima
Im sure the manual will tell you if you read it, but I guess its a low
light mode and it probably is indicated on the screen
Thanks for replying!
No, it's not the low light mode. I do not enable it and it is not
indicated on the screen.
ransley
You said panoramic is that a special wide mode, if its new take it
back, sony manuals are junk, and I found options even Sony support did
not even know that are not in my manual, that I could shoot stills
while taking video on an old unit. They have so much new stuff out its
hard to know all the operating parameters on every model. Keep looking
you will figure it out, but color slow shutter may be automatic and
its on with Night Shot on mine
its on with Night Shot on mine- Hide quoted text -
- Show quoted text -
Thanks Mark for replying!
Panoramic video means that you turn a camcorder around its axis during
recording.
The Color slow shutter mode does not turn automatically, but manually
only.
recording.
<snip>
What?? If that is the actual function setting, it makes no sense at all to
have such a setting. You could do the same thing with any video camera. Are
you sure it is not a wide screen setting?
Mike- Hide quoted text -
Thank Mike for replying!
What "function setting" do you mean?
I meant panning shooting by a panoramic video.
I use wide lens angle usually during panning.
"D" <[email protected]> wrote in message
recording.
Are
Oh, I understand what you mean now. Reading through this I thought you meant
there was a panoramic setting. Now I understand you are using a wide angle
lesnse and taking a panoramic shot.
Apprently you are not the only one having problems with this camera.
If you just bougth it return it and get another to see if it has the same
problem.
Thanks Michael for replying!
I bought it half a year ago.
recording.
Are
problem.
recording.
Are
problem.
Hello!
The Sony service says today that the camcorder is normal. The contact
personel did not test the camcorder. The Sony service does not allow
to contact technicians which tested the camcorder the days before.
Sincerely.
