Free 3D Maxwell's equations solver for cylinder cavity resonator?
Calvin Guan
I'm trying to build an air filled cylinder cavity resonator excited by
coaxial probe like this:(view using fix font)
port1 50 ohm coax feedline port 2
| ___________________ |
V | | V
tuning screw
The coax probe is expected to excite the E field inside the cavity. The
resonator is expected to work in TM011 mode. I want to solve the E and M
fields inside the cavity and get the S parameters giving the size of the
cavity, the probes and the characteristics of the metal. My EM theory tells
me this configuration should work. I'm not a paid RF/MW engineer or an
academic so I couldn't afford the commercial EM solver. This is a hobby
project. Does anyone know if there is any free solver can handle this
problem? Is this problem best solved by FDTD? How about MoM and FEM?
thanks,
Calvin
Calvin Guan
No answer?
I did a lot of research and knew that this is not a simple problem as I
thought. I think I need to code my own fullwave solver and hopefully make it
available for free if I ever get it working.
Calvin Guan
I worked on my own 3D fullwave solver on and off. Now it's WORKING - well
kind of. From my simulation, I found it easier to rearrange the probes to
excite the cavity in TE011 instead of TM mode. It's easier for me to build.
Calvin
