Jonas said:
Hi
I wonder how I shall choose a correct freewheel diode. Which
parameters are necessary to consider?
Jonas
Usually the most important parameters to keep in mind are the voltage
rating, current rating, reverse recovery speed/reverse recovery charge,
average power dissipation, and maximum peak die temperature (under both
normal and reasonably anticipated transient conditions).
Generally speaking if any of the above listed items aren't properly
accounted for in your selected diode, the device will likely end up
destroyed.
Once you have the above parameters satisfactorily covered, then you can
further optimize your diode selection by considering some other parameters
such as: forward voltage, minimum EMI radiation, reverse leakage current,
packaging/size, cost, availability, etc.
Usually in low voltage (IE: <100V) applications schottky diodes make for
good freewheeling diode choices.
