Freq. of Circ. Pol. Field
K
Ken Sutton
If I have four 100Hz sinewaves with a 0, 90, 180, 270 degree phase
relationship and apply one each to four coils in a circular array,
what is the actual frequency of the applied wave?
I know the rotational speed will be 100Hz, but is there a 400Hz field
component?
Ken Sutton
U
Uwe Hercksen
the same 100 Hz. By the way, you only need two sinewave signal with 90 °
phase shift, the rest is done easily with proper connection to the four
coils. 270 degrees phase shift result from the 90 ° signal connected
with both ends changed.
Bye
