Frequency dependent resistor in PSpice
Bala_01
May 30, 2016
6
Think a simple case. I want to create frequency dependent resistor R1. The value of R1 is as follows:
at 1 MHz -> R1 = 2
at 5 MHz -> R1 = 10
at 10 MHz -> R1 = 20
at 100 MHz -> R1 = 200
Thant means R1 is a function of frequency where R1=2* Frequency. Consider only the numerical value of frequency not unit. How can I implement in Pspice ?
Best regards,
Bala
14,487
pretty sure there's no such thing as a frequency dependent resistor
in my 40+ yrs of electronics have never heard of one
so what are really trying to achieve ??
Bala_01
May 30, 2016
6
I have found the solution. It can be done with Laplace transformation.
************ Test ***************
.subckt Test01
+ 1 2
G_Rvar1 1 2 LAPLACE { V(1)} {1 /((1/K1)*(s/(2*PI)))}
.param K1=1
.param PI =3.141592654
**********K1=1 when Frequency in Herz
**********K1 =1e6 when Frequency in MHz
.ends
I need this info to test a HV Filter.
Bala
LvW
Apr 12, 2014
604
Perhaps, this is not what the OP (Bala_01) needs - but there is a very versatile active circuit called "Frequency-Dependent Negative Resistor (FDNR) " consisting of two opamps. Such a device is extensively used in active filters and harmonic oscillators. It is a special version of the universal GIC circuit.
Alec_t
Jul 7, 2015
3,821
Can't you just right-click on the resistor value in the schematic and set the value to {2*frequency} ? Then add a directive .param frequency=3meg (or whatever).
Bala_01
May 30, 2016
6
I need a Pspice netlist model which I can import in CST DS.
CDRIVE
May 8, 2012
4,960
Ha, I know that this is not what you meant but attempting to use a wire-wound resistor as a 50Ω RF Dummy-Load comes close to fitting the definition. :D
Chris
