Frequency Detector
Unthoughtof
Mar 4, 2014
3
Hi I am working on a project for school and I am running into problems. The project uses a transmitter and receiver to operate. I am putting a set frequency into the transmitter and getting the same frequency on the receiver end. What i need now is a circuit that can detect a set frequency and then activate a relay to operate a motor. Any help would be greatly appreciated!
duke37
Jan 9, 2011
5,364
You will need to make a circuit to tune to the incoming frequency. In olden times, a circuit made with an inductor and capacitor was used. Nowadays an amplifier is used to eliminate the inductor. You will need to know the frequency to calculate the components.
Once the tone has been detected, it can turn on a transistor which will activate the relay.
Inforrmation you need :-
Power supply details
Frequency
Op-amp details
Relay details
Unthoughtof
Mar 4, 2014
3
Thank you for the reply. I am using a 555 timer to generate my frequency. So i know the frequency that is coming out, the only thing i need is where to start as far as the detection circuit, i am trying to use a 567 but not having much luck.
Arouse1973
Adam
Dec 18, 2013
5,178
Can you post the circuit diagram and the PCB if you have one.
Adam
Externet
Aug 24, 2009
944
The NE567 works very well and reliable, for sinewaves. A 555 outputs square or triangle waves and will not yield a very stable detection.
I have not found a monolithic sinewave generator IC. Somehow they are not built. It would be nice to set a capacitor and variable potentiometer on a chip pins, at 555 style and get a clean oscillator. Alittle more complex IC that does it is the ICL8038
duke37
Jan 9, 2011
5,364
The 8038, will generate a reasonable approximation to a sine wave and is tunable.
If you do not want to vary the frequency of the tone, you could put a filter after the 555 or before the 567. The 567 is a phase locked loop with two detectors. One or the other should work on non sine waves.
Unthoughtof
Mar 4, 2014
3
So if I can convert the Square wave coming out of the 555 into a sinewave then the 567 will be able to detect that better ?
duke37
Jan 9, 2011
5,364
Obviously, the cleaner the signal into the 567 the better.
It is a long time since I read up about the 567 but I remember that one of detectors will lock onto harmonics. This you do not want. I suggest that you chose the best detector for your purposes.
