Frequency generator, level adjust
bigkim100
Apr 17, 2013
270
Im using the xr2206 as a square wave generator, but the voltage output of this is too high.
How can I bring the voltage output of this down, without distorting the signal?
Thank You
14,317
Use a resistive divider? Or a transistor stage.
What is your load (resistance or current)?
bigkim100
Apr 17, 2013
270
I need it to be running at 1v peak, I do not know the resistance of what Im using, its a 3vdc transistor radio
a friend of mine used a variable violtage regulator to do this, but I think I want a more basic way to do this
bigkim100
Apr 17, 2013
270
I cannot find any schematics that use a transistor stage in its design...any ideas??
bigkim100
Apr 17, 2013
270
Have a look at this ESP project:
https://sound-au.com/project22.htm
Figure 4 shows how to make a signal level control section.
Bertus
This is an excellent reference, but I have a question
Looking at figure 4 of the frequency generator/attenuator website, can the actual attenuator be run from 9v, or should it be lower??
I see the power supply of the attenuator is not shared with the frequency generator....I think, is this the case??
bigkim100
Apr 17, 2013
270
Bertus
AnalogKid
Jun 10, 2015
3,058
In the ESP project page, both the oscillator and the attenuator are powered with +Ve, -Ve, and GND, so I don't understand your question.
The attenuator circuit is a unity-gain buffer driving a resistor divider. The buffer (Q1, Q2, etc.) can be replaced with an opamp in the voltage follower configuration if that is easier for you.
ak
bigkim100
Apr 17, 2013
270
I was just wondering if the 2 transistor attenuator stage was powered from a different supply than the actual oscillator stage.
What voltage does the attenuator require?
AnalogKid
Jun 10, 2015
3,058
There is a link to a power supply project near the top of the page.
Looking at the oscillator circuit, I would guess it would run on voltages as low as +/-12 V. The attenuator will run on lower voltages such as +/-9 V, but the oscillator might start to clip.
ak
bigkim100
Apr 17, 2013
270
ak
Thanks Analogue
