frequency to voltage conversion question
bonanz1
Sep 11, 2003
24
Hello all,
I am working on a model scale maglev train. along the track there are sensors that detect the positino of the vehicle and power current through a respective coil to form a LIM. I wanted to find an easy way to monitor the speed of the train by using the sensor frequency (evenly spaced) and to give an output. I am not real fond of microcontrollers so i planned to use an LM2917/LM2907 frequency to voltage converter, and then use that voltage to drive a row of led's using a LM3914. The only thing i didnt take into consideration is the train with respect to sensor position (about 4 inches apart) will be outputting a frequency at maximum of 1Hz which would not produce barely any voltage at all coming out of the FTV and therefore not drive the led's. I was wondering if someone was familiar with a way of multiplying such a low frequency into something that the FTV converter would find useful to put out a reasonable voltage, or possibly a simple, yet entirely different approach.
bonanz
btw. love this site, plan on hanging a round a lot
mixos1
Administrator
Jul 13, 2003
581
I found this Frequency Multiplier:
http://users.otenet.gr/~athsam/frequency_multiplier.htm
I think it's exellent for your case. With it you can multiply a frequency of 1Hz (or below) a hundrent times.
Which is the minimun frequency that LM2917/LM2907 can be driven?
