Fuel level senders
F
Franc Zabkar
Could someone please explain why rheostat type fuel level senders as
used in automotive petrol tanks are considered safe? Intuition would
suggest that an intermitent contact could pose an ignition problem,
especially when the tank is full of vapour.
- Franc Zabkar
Rheilly Phoull
One day Franc Zabkar got dressed and committed to text
- Franc Zabkar
I imagine the current levels would preclude any arcing. Certainly they have
stood the test of time Franc :)
Tony Williams
as used in automotive petrol tanks are considered safe? Intuition
would suggest that an intermitent contact could pose an ignition
problem, especially when the tank is full of vapour.
Ignition also needs the correct proportion of oxygen,
and (afaik) there is never enough oxygen in there.
IIRR they are safe precisely because the petrol tank is full of vapour
- to get a dangerous mixture of petrol vapour and air you need an empty
petrol tank, because the saturation concentration of inflammable gases
above liquid petrol/gasoline at room temperature is too high to sustain
combustion (the fuel-air mix is too rich).
That is, the fuel concentration is above the Upper Explosive Limit
http://www.imakenews.com/aristatek/e_article000126616.cfm
Jeroen Belleman
Right, and the limits are pretty narrow as well. I remember playing
with a cork gun, a piece of steel tube with a spark plug at one end
and a cork at the other. Three drops of petrol popped the cork 20m
high. Two or four drops did nothing.
Jeroen Belleman
Don Pearce
Jeroen Belleman
Years ago, helping a friend respray a car, we had a steel dustbin that
gradually got filled up with old rags soaked in cellulose thinners. At
the end of the day we decided to burn the rags, so we lit them through
a small hole in the bottom of the bin.
We never found the dustbin lid, and I have no idea how high it went.
d
Pearce Consulting
http://www.pearce.uk.com
John Larkin
Jeroen Belleman
d
I had a friend who tried to solder a leaky, assumed-empty car gas tank
with a propane torch. It came out sort of spherical.
John
Pooh Bear
This is what is alleged to be what went wrong on TWA 800 ( the fuel air mix
that is ).
Graham
Pooh Bear
Jeroen Belleman
d
John
I see you use the past tense ' *had* a friend ' !
Graham
Jim Thompson
That was a surface to air missile.
Paul! Paul! Paul! Paul!
Get real. Everyone in the industry knows the failure mechanism was in
the tank-to-tank pump.
Sheeesh!
...Jim Thompson
Paul Hovnanian P.E.
that is ).
K
Keith Williams
Nonsense. The pilot wasn't wearing his tinfoil hat when he was hit
with an Illudium PU36 Explosive Space Mudulator beam.
Remember, shiny side out!
Rich Grise
Jeroen Belleman
d
I saw a guy at a car shop who had taken the gas tank off some car, and
poured the leftover gasoline into a 5-gallon bucket. Not very much
gasoline, there was about 1" - 2" of gasoline in the bottom of the bucket.
We were all smoking, (back in those days, almost everybody smoked) and I
said to the guy, "Hey, I've heard that a lit cigarette won't ignite
gasoline. Do you know if that's true?" He didn't say anything, just took
his cigarette and flicked it into the bucket. It went "SSst" as if it had
been flicked into water.
Cheers!
Rich
F
Franc Zabkar
I've never really doubted that petrol tanks are safe. I just wanted to
know why. As for low current being the reason, I'd expect that the
tank would need to tolerate the situation where the full supply
voltage was applied to the sender when it was at the low end of its
resistance range. I imagine this could occur as the result of a wiring
error during a dashboard repair, say, or if the fuel gauge failed in
some peculiar way.
- Franc Zabkar
F
Franc Zabkar
Thanks, that makes sense. I guess it is very difficult to achieve a
stoichiometric ratio inside the fuel tank.
I recall a friend who was a panel beater telling me that he used to
weld petrol tanks after filling them with fuel. His colleagues thought
he was mad, but he survived, only to die of prostate cancer many years
later.
- Franc Zabkar
Clifford Heath
It's not uncommon to feed a pipe from the exhaust of a running car
into a fuel tank so you can weld it safely. It's easier to remove
the oxygen than to remove the residual fuel...
Paul Hovnanian P.E.
Wrong. From http://www.ntsb.gov/Publictn/2000/aar0003.htm
"The National Transportation Safety Board determines that the probable
cause of the TWA flight 800 accident was an explosion of the center wing
fuel tank (CWT), resulting from ignition of the flammable fuel/air
mixture in the tank. The source of ignition energy for the explosion
could not be determined with certainty, but, of the sources evaluated by
the investigation, the most likely was a short circuit outside of the
CWT that allowed excessive voltage to enter it through electrical wiring
associated with the fuel quantity indication system."
They don't really know what caused the CWT to blow, but they are pinning
the problem on the FQIS. So much for the theory that fuel level senders
are safe. Cars should be blowing up right and left on the freeway from
the senders, not to mention immersed electric fuel pumps.
What I wonder about is: Following the accident, the FAA attempted to
identify and interview the crew of every aircraft operating in the area.
One aircraft, shown on radar flying in circles nearby, was never found
and no crew ever came forward. There is one type of aircraft that
exhibits this behavior. A target drone.
K
keith
They (and the electric pump) are usually submursed under the fuel. It's
never a good idea to run the tank dry because the fuel also lubricates
the pump bearings.
