fully differential opamp implementation
tiger66
Hi All
I need a fully differential opamp for my circuit design.
Unfortunately, the simulator I use, multisim, does not have a build in
fully differential opamp.
So, I was wondering if any of you have experience implementing a fully
differential opamp, can you please help me to implement one?
Any resources (i.e. netlist, circuit diagram) will be really
appreciated
thanks
John Larkin
Hi All
appreciated
thanks
google "three opamp differential amplifier". Or cheat and use a Spice
vcvs, which is a perfect diffamp.
John
F
Fred Bartoli
But the output is not diff.
But the output isn't referenced WRT to common mode. You'll have to use 2
VCVS for this, or 3 if you don't want to reflect the output current to
the CM ref input.
Jim Thompson
Hi All
appreciated
thanks
I'll knock one out for you for $25K, payable upfront ;-)
...Jim Thompson
tiger66
John
Thanks very much John for the response.
I was designing my fully differential opamp using "three opamp
differential amplifier" concept initially because it only requires two
basic opamps and 4 resistors which my simulator has all the
components.
Unfortunately, after I connect the input of the three opamp
differential amplifier to the output of my modulator, I get "timestep
too small" error message when simulate. Do you know how to debug this
problem?
Currently, my circuit can simulate fine using vcvs as you suggested.
Do you know if there are any disadvantage for using vcvs instead of
normal fully differential opamp? Would it affect my output signal
spectral analysis significantly?
Thanks again for your assistant
tiger66
the CM ref input.
Hi Fred
Are you talking about "common mode feedback circuit"?
I was reading about that when I was researching about fully
differential opamp. Unfortunately, I can't find a detailed explanation
about the CMFC(i.e. the articles only show the schematics but not the
values I should use for MOSFET, capacitor, resistor and reference
voltage). So I really don't know how to integrate CMFC with opamp.
Do you have experience implementing the fully differential opamp? Can
you send me a netlist of that, so I know what values to put for each
components
tiger66
...Jim Thompson
| James E.Thompson, P.E. | mens |
| Analog Innovations, Inc. | et |
| Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
| Phoenix, Arizona Voice:(480)460-2350 | |
| E-mail Address at Website Fax:(480)460-2142 | Brass Rat |
| http://www.analog-innovations.com | 1962 |
I love to cook with wine. Sometimes I even put it in the food.
Thanks for the offer Jim, but I am a poor engineering student. So I
can't afford that kind of money
But I think I can offer you $1 if you can help me design a fully
differental opamp. $2 if you can help me design a chopper stabilized
amplifier
Jim Thompson
components.
problem?
"Perfect" VCVS has no delay or phase shift, infinite bandwidth... all
of the constituents of instability.
Back up and study how to model an OpAmp, with at least one pole.
...Jim Thompson
Eeyore
tiger66 said:
Hi All
I suspect you don't mean 'op-amp' you probably mean differential amplifier.
Graham
John Larkin
Is that what he meant by "fully differential"?
the CM ref input.
Whatever.
John
John Larkin
components.
problem?
If you are trying to evaluate the spectral properties of a diff-output
mixer, the vcvs is literally ideal. An opamp thing will just add its
own complications and abberations.
If you eventually want to build the circuit, you will need a diffamp,
I suppose. Or a transformer. There are some nice, integrated, very
fast diffamps around these days.
John
Marte Schwarz
If he search the spice models he should look by the factories...
http://www.ti.com/litv/zip/sloj158
may be a good start.
Marte
tiger66
Marte
Thanks, I guess I need to learn how to use Pspice now.
Can Pspice generate the Power Spectral Density of a signal? I need to
do some spectral analysis in my circuit
Ban
tiger66 said:
Hi All
appreciated
thanks
With the 3 opamp IA circuit you can just add an identical output
differential amp stage with the inputs inverted to obtain the other output
signal.
Jim Thompson
Yes.
Yes. You can do a spectral analysis in Probe, or can define
distortion analysis in the setups to get a table.
...Jim Thompson
Marte Schwarz
Hi tiger,
You do not need to switch the program. Multisim can use (p)Spice models as
well as LTSpice for example. The changes that may have to be made are very
little and almost known in the support forums.
Marte
.... who prefers to use LTSpice
V
vasile
Even it can, and even if you do it right on simulation, on the real
world will be different
(could be very different at high frequencies)
Focus on fully differential OA datasheet available at Analog Devices,
Texas Instruments and Linear Technology.
There are a lot of articles about those. Some clues: AD8132, THS4121,
LT1994
John Larkin
signal.
The cold end of the resistor going into the + input of the 3rd amp is
the output reference; it need not be ground.
John
tiger66
Hi tiger,
Marte
Hi All
Does anyone have experience using multisim?
I keeps getting a "timestep too small" error message when I simulate.
I tried all the debugging method I found online, but non of them
solves my problem
Any input/assistant on this would be really appreciated
thanks
Eeyore
solves my problem
I told you before.
It's crap.
Graham
