G24-q3 lampholders
Andrew Gabriel
Any suggestions for a UK supplier of G24-q3 compact fluorescent lampholders?
Only want a couple, but can't find anyone stocking them.
Looking for the type which holds the tube parallel to the mounting surface.
I want to modify a luminare which uses a G24-d3 (2-pin with integral
glowstarter) and magnetic ballast over to an electronic ballast with
4-pin lamp.
Andrew Gabriel
Contact Vossloh Schwabe through www.vossloh-schwabe.com. They are a
manufacturer with probably the best range of different fixing
arrangments for particular holders and so on - check out their online
catalog, which leads you through very well to the right product. They
are the manufacturer, so they don't supply small numbers, however, they
have a database of who has stock of their products, so that should work
out.
I've always found them easy to deal with. If you meet a rep, however,
please slap them for their failure to provide lamp bases for Linestra.
Very hard please.
Thanks. Spoke with them but their minimum quanitites are 500 pcs.
They gave me a distributor's name, http://www.bernlite.co.uk, who
sounded quite happy to supply me over the phone. Downloaded Bernlite's
catalogue, and it's got lots of things in it which I've been trying
to find sources for some time.
