GCSE homework
bertus
3,877
The question is pure theoretical.
A transistor will never be saturated with the given base current of 4.5 mA.
In practice we use Ib =Ic/10 for saturation of a switching transistor.
In your example the transistor should have a gain of 3.6 / 0.0045 = 800 times.
Can you show your calculation of the base transistor in your case?
Can you show the complete page of the task?
Bertus
danadak
Feb 19, 2021
1,104
A representative look at transistor saturation :
The "classic" rule of thumb to sat a transistor is to force Icollect/10 or more into the base.
This is called forced beta in the industry jargon. But its a rule best used by examining the
datasheet for sat behavior. You can see here if Ic = 1A in active region it takes ~ 20 mA
to get transistor into saturation, not the 100 mA the rule would imply.
Attached a good discussion on saturation.
Regards, Dana.
  • lecture5_6.pdf
